mafiosa
Container for mDNS repeater
Sat Jun 18, 2022 4:42 pm
Can someone post the steps to get a working mDNS repeater using v7.4 beta 4 containers?
rutman286
Re: Container for mDNS repeater
Tue Jul 05, 2022 7:05 am
THIS... THIS a million times please!! I have the pinhole container working like a charm. That is 50% of what I need. The MDNS repeater container would be amazing.
devinganger
Tue Jul 05, 2022 8:32 am
The mDNS containers I've seen all require bridged networking in the Docker container. Is that supported on the RouterOS containers>
mickey
Tue Jul 05, 2022 9:28 am
I've manage to create container with mdns-repeter between two VLANs. Here https://github.com/TheMickeyMike/docker ... r-mikrotik is repo with short README and my setup
This repo was created in hurry and it is one big work in progress, because now I'm trying to write my own mdns-repeter in GoLang with L2 support and some filtering, something like this https://github.com/Gandem/bonjour-reflector, but without using libpcap, pure Go.
rutman286
Fri Sep 23, 2022 1:46 am
Hi Mickey, any updates on your mans repeater container?
mickey
Fri Sep 23, 2022 9:08 am
I've tried doing it in Go, but lack of libs for L2 operations forced me to pivot into rust-lang. Unfortunately I don't know rust so I've started learning it... it's not easy and very time consuming process, sooo don't count on me :lol:, but my "temporary" container with mdns-repeater.c (without filtering) works like charm 8)
atgsleepless
Sun Oct 16, 2022 9:38 pm
You sir deserve a beer! This does work like a charm, only had to change the vlan ids. Wireless devices can now cast to wired tv and oculus quest2 can now airlink to wired pc.
berzerker
Fri Nov 04, 2022 2:13 am
Just want to say that I also had success with this container! Thank you again for your work.
Just a note that the VLANs should be changed/specified in *both* the run.sh file and the Dockerfile. I initially missed that and was wondering why the ethernet interfaces weren't getting created correctly.
Valerio5000
Tue Dec 06, 2022 1:14 am
could this make sure that even through VPN there is connectivity via mDNS?
theprojectgroup
Sat Mar 04, 2023 10:41 pm
Thanks a lot for the great work and building the container image!
I just wrote a little HowTo set this up: viewtopic.php?t=194185&hilit=mdns+repeater+container
Now I'm able to share Airprint and Airplay with my guest vlan / wlan.
Users browsing this forum: antonsb, Bing [Bot] and 3 guests
