displacedbuck
VLAN communication Help
Sun Jun 19, 2022 5:13 pm
I could use some assistance fixing my configuration. I have been unable to get communication between my main network and the vlan10 which i am setting up for virtual machines. At this point i am sure my configuration has several errors since i have been trying multiple solutions. However, all vlans work on their own, have internet access, and dns works.
The main network and VLAN10 share dns, VLAN2 has its own dns and VLAN100 has its own dns. THis allows stricter filtering for kids network and looser filtering for iot devices. I want to keep these separate and not communicating out. I would like the main network to be able to communicate to the VLANS and main and VLAN10 to communicate both ways.
I am attaching the current config and a rough diagram. Any guidance would be greatly appreciated.
add admin-mac=DC:2C:6E:40:FB:49 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether2 name=guest vlan-id=2
add interface=bridge name=iot vlan-id=100
add interface=bridge name=main vlan-id=1
add interface=bridge name=virtuals vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool1 ranges=192.168.1.150-192.168.1.251
add name=dhcp_pool2 ranges=192.168.2.150-192.168.2.254
add name=dhcp_pool3 ranges=192.168.100.150-192.168.100.254
add name=virtual_pool ranges=192.168.10.20-192.168.10.250
add address-pool=dhcp_pool1 interface=bridge name=maindhcp
add address-pool=dhcp_pool2 interface=guest name=guestdhcp
add address-pool=dhcp_pool3 interface=iot name=iotdhcp
add address-pool=virtual_pool interface=virtuals name=virtualdhcp
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp-sfpplus1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=bridge tagged=ether2 vlan-ids=10
add bridge=bridge tagged=ether2 vlan-ids=100
add bridge=bridge tagged=ether2 vlan-ids=2
add interface=virtuals list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.1.1/24 comment=defconf interface=bridge network=192.168.1.0
add address=192.168.2.1/24 interface=guest network=192.168.2.0
add address=192.168.100.1/24 interface=iot network=192.168.100.0
add address=192.168.10.1/24 interface=virtuals network=192.168.10.0
/ip arp
add address=192.168.1.100 interface=bridge mac-address=70:85:C2:B1:C3:89
add
/ip dhcp-client
add comment=defconf interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.10 client-id=ff:42:69:65:2d:0:2:0:0:ab:11:eb:6b:a9:3f:3b:1d:e0:87 mac-address=74:83:C2:11:70:2B server=maindhcp
add address=192.168.1.20 client-id=1:40:9f:38:fc:f:4f mac-address=40:9F:38:FC:0F:4F server=maindhcp
add address=192.168.1.99 client-id=1:a0:ce:c8:38:ef:de mac-address=A0:CE:C8:38:EF:DE server=maindhcp
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 domain=mydomain gateway=192.168.1.1 netmask=16
add address=192.168.2.0/24 comment="kids and guests" dns-server=45.90.28.146,45.90.30.146 domain=mydomain gateway=192.168.2.1 netmask=24
add address=192.168.10.0/24 comment=virtuals dns-server=192.168.1.1 domain=mydomain gateway=192.168.10.1
add address=192.168.100.0/24 comment=iot dns-server=8.8.8.8 domain=iot.mydomain gateway=192.168.100.1 netmask=24
set allow-remote-requests=yes use-doh-server=https://dns.nextdns.io/myid verify-doh-cert=yes
/ip dns static
add address=45.90.28.0 name=dns.nextdns.io
add address=45.90.30.0 name=dns.nextdns.io
add address=2a07:a8c0:: name=dns.nextdns.io type=AAAA
add address=2a07:a8c1:: name=dns.nextdns.io type=AAAA
add address=192.168.1.20 name=canone58496.mydomain ttl=30m
add address=192.168.1.1 name=mikrotik.mydomain ttl=30m
/ip firewall address-list
add address=192.168.1.0/24 list=main
add address=192.168.10.0/24 list=virtuals
add action=drop chain=input comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=input comment="defconf: accept ICMP" log=yes protocol=icmp
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" disabled=yes dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" disabled=yes ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" disabled=yes ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid disabled=yes
add action=accept chain=forward comment="INTERVLAN: main to virtuals" in-interface=bridge out-interface=virtuals
add action=accept chain=forward comment="INTERVLAN: virtuals to main" in-interface=virtuals out-interface=bridge
add action=accept chain=input comment="virtuals VLAN DNS Access" connection-state=established,related,new dst-port=53 in-interface=virtuals protocol=udp
add action=accept chain=input comment="virtuals VLAN DNS Access" connection-state=established,related,new dst-port=53 in-interface=virtuals protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input dst-address=192.168.1.25 log=yes src-address=192.168.1.240
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.1.0/24
set ssh address=192.168.1.0/24 port=2222
set api disabled=yes
set winbox address=192.168.1.0/24
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=America/Chicago
/system identity
set name=microtik
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes multicast=yes
/system ntp client servers
add address=66.228.58.20
add address=45.63.54.13
add address=38.229.56.9
/system routerboard settings
set auto-upgrade=yes
/tool mac-server
/tool mac-server mac-winbox
Sob
Re: VLAN communication Help  [SOLVED]
Mon Jun 20, 2022 2:55 am
In DHCP server config, netmask=16 for main subnet is wrong. That's what clients get, so 192.168.1.x client then expects that 192.168.10.x (and any other 192.168.x.x) is directly reachable, but it isn't.
displacedbuck
Mon Jun 20, 2022 3:13 am
Thanks. That solved main being able to reach the other subnets.
Still having issues with virtuals -- VLAN10 being able to reach main.
Sob
Mon Jun 20, 2022 3:57 am
If main can reach vlan10, then vlan10 should reach main too. Routing must be ok, otherwise neither would work. And firewall doesn't block it either.
displacedbuck
Mon Jun 20, 2022 4:30 am
Sorry. You are correct. I had to reboot the server to get it to see the netmask changes.
All appears to be communicating as expected now.
Users browsing this forum: Bing [Bot], jamesperks, qatar2022 and 65 guests
