For an introduction, you can follow the Container Wiki Page including a tutorial to enable containers and set up a Pihole DNS server.
I've decided to create a generic container image to be able to SSH into it and play around. It is probably not the best use of Docker containers but gives you a tiny handy isolated Linux server running directly inside the router to try different ideas and do benchmarks without the hassle of externally creating and testing images each time.
Prebuilt containers include common utilities such as vim, curl, speed-test and iperf3 with an enabled open-ssh server. You can install additional packages using apt-get (debian) or apk (alpine) or build a customized version from the Docker files provided.
Here are some screenshots of the Debian and Alpine containers running on my RB5009UG+S+IN.
Step 0: Backup and Requirements
Make sure to backup your router configuration and be aware this is still an experimental feature. And make sure to have:
- RouterOS device with RouterOS v7.4beta or later and installed Container package
- Physical access to a device to enable container mode
- Attached hard drive or USB drive for storage - formatted as ext3/ext4
Download the latest 7.4beta version of router os + extra packages (container). Then move them to the router using Winbox > Files and reboot to install.
After reboot, enable container mode. You need physical access to turn off or reboot the router to enable container mode.
Code: Select all
/system/device-mode/update container=yes
Add veth interface for the container:
Code: Select all
/interface/veth/add name=veth1 address=172.17.0.2/16 gateway=172.17.0.1
Code: Select all
/interface/bridge/add name=dockers
/ip/address/add address=172.17.0.1/16 interface=dockers
/interface/bridge/port add bridge=dockers interface=veth1
Code: Select all
/ip/firewall/nat/add chain=srcnat action=masquerade src-address=172.17.0.0/16
Download the docker image and transfer it to the router.
If you prefer to build the images yourself for a different architecture use Docker files and entry from this gist and build against your router's CPU architecture. I've hosted some prebuilt images for easy use.
We the fetch tool to download into the router directly but you can use your preferred method to fetch the links.
[ARM64] Debian (300MiB): (if you have enough space on an external disk, go for it!)
Code: Select all
/tool/fetch url=https://dl.home.pi0.io/mikrotik/docker/debian.arm64.tar dst-path=disk1/images/linux.tar
Code: Select all
/tool/fetch url=https://dl.home.pi0.io/mikrotik/docker/alpine-slim.arm64.tar dst-path=disk1/images/linux.tar
Code: Select all
/tool/fetch url=https://dl.home.pi0.io/mikrotik/docker/alpine.arm64.tar dst-path=disk1/images/linux.tar
Set an env to autoconfigure SSH root password (value is an example. use something more secure!)
Code: Select all
/container/envs/add list=linux_envs name=PASSWD value="letmein"
Code: Select all
/container/mounts/add name=linux_data src=disk1/docker/linux_data dst=/data
Code: Select all
/container/add file=disk1/images/linux.tar interface=veth1 envlist=linux_envs root-dir=disk1/docker/linux_root mounts=linux_data hostname=mikrotik
Code: Select all
/container print
Code: Select all
/container start 0
Code: Select all
/container print
Step 5: Connect to the container
You can ssh into the container using `ssh -v root@172.17.0.2`. Use the password defined in earlier steps (default is letmein).
Happy hacking and please share your feedback and ideas in the forum!
