pxcorp
Problem with array constant
Mon Jun 20, 2022 12:18 am
Hello I have problem with reusing associative array initializer in loop - first pass works OK, but next passes initialization not working. It is also reproducible in terminal console:
:foreach i in={"a";"b";"c"} do={:local x [:toarray ""]; :set x {"a"=1;"b"=1;"c"=1}; set ($x->$i) 2; :put [:tostr $x];};
a=2;b=1;c=1
a=2;b=2;c=1
a=2;b=2;c=2
(ros 6.49.6)
update: It is not working either with nonassociative array a also when done indirectly via another variable. And what is evene worse - it is changing original variable uset for setting value. So it looks like that inside :set command array is not copied but referenced.
:local y {1;1;1;1};:foreach i in={1;2;3} do={:local x [:toarray ""]; :set x $y; set ($x->$i) 2; :put [:tostr $x];:put [:tostr $y];};
1;2;1;1
1;2;1;1
1;2;2;1
1;2;2;1
1;2;2;2
1;2;2;2
Can anybody explain this to me ?
rextended
Re: Problem with array constant
Mon Jun 20, 2022 12:29 am
missing : here: "; set"
But I do not see anything strange, what you expect?
EDIT:
still missing : here: "; set" on both examples
pxcorp
Mon Jun 20, 2022 12:38 am
Yes that is typo in command, but it works exactly same way with and without : - in both cases parser not complain about syntax error and behavior is exactly same.
rextended
Mon Jun 20, 2022 12:43 am
Still not change that is work exactly as expected, what is your problem?
pxcorp
Mon Jun 20, 2022 12:54 am
totally wrong result of script
right result should be
a=2;b=1;c=1
a=1;b=2;c=1
a=1;b=1;c=2
Just found that in ros v7.3.1 it works correctly (and if set is with : doesn't matter to):
a=2;b=1;c=1
a=1;b=2;c=1
a=1;b=1;c=2
:foreach i in={"a";"b";"c"} do={:local x [:toarray ""]; :set x {"a"=1;"b"=1;"c"=1}; :set ($x->$i) 2; :put [:tostr $x];};
a=2;b=1;c=1
a=1;b=2;c=1
a=1;b=1;c=2
rextended
Mon Jun 20, 2022 12:58 am
You mentioned v6, on v7 it works differently, it's this way by design.
And about ":", your perseverance to write it on wrong way is really silly, until you work on "root" works, but after you change the "working path", assume a different function...
and : say to the "compiler" that you want use the "root" command set, and not the "set" on local context...
/ip
:local test ""
:set test "y"
set test "x"
pxcorp
Mon Jun 20, 2022 1:25 am
I don't know how is :set command implemented inside ros v6 and v7, in fact probably only few people know that. But it does'n matter - it should assign value of second parameter to first one.
In manual there is exactly written: ":set <var> [<value>] assign value to declared variable." - this seems perfectly clear and logical.
But my question is why (in ros v6) :set x {"a"=1;"b"=1;"c"=1} assign to x {"a"=1;"b"=1;"c"=1} in first pass, {"a"=2;"b"=1;"c"=1} in second and {"a"=2;"b"=2;"c"=1} in third - that is not much expected behavior.
Maybe I missed something important in manual, but if not then it looks like that :set implementation for array in ros v6 is somehow broken.
And to ":", it should be there, I misstyped it when testing behaviour from console. Parser doesn't protest, you noticed that is missing. Just to be sure that problem is not caused by that I tested both variants first in v6 and then in v7 to have exactly same testing scenario. Teoretically it should not work without :, but somehow it doesnt matter to parser. But that is not problem which I talking about - problem is that incorrect value end up in variable.
PS:
Ive found this when writing quite complex script (after hour of debugging why first item is processed corectly and subseqent items not) and posted code is cutted down to show exact where I see problem.
Users browsing this forum: CoMMyz, Google [Bot] and 12 guests
