DeltaCreek
Trouble with Unifi switch on network
Mon Jun 20, 2022 11:08 am
Hello. I recently purchased and set up my first Miktrotik router (Hex S). My previous set up was as follows:
Cable modem/router -> Ubiquiti Unifi Flex Mini -> 2 Unifi access points
I switched it to:
Cable modem -> Miktrotik Hex S -> Unifi AP
                               -> Unifi Flex Mini -> Unifi AP
When the Unifi Flex Mini is on the network, the internet connection was spotty and browsing was slow. My wife and I frequently saw warnings on our iPhones that our Wifi wasn't able to connect to the internet. The Unifi app reported that the Flex Mini was offline every few hours. I then removed the Unifi Flex Mini from the network and everything appeared to operate normally.
Has anyone experienced issues when a Unifi switch is connected to a MIkrotik router? How can I debug what's happening?
Thanks.
DeltaCreek
Re: Trouble with Unifi switch on network
Mon Jun 20, 2022 8:49 pm
My wife told me the internet has been terrible all day so maybe it wasn’t the switch after all.
I’m going to try to set up a script to monitor WAN connectivity.
From the outside, things appear fine:
Buckeye
Forum Veteran
Forum Veteran
Mon Jun 20, 2022 10:20 pm
My experience is that switches ether work or they don't, although I have seen some weird problems with some really old switches (that probably had a bad memory chip) that would create a lot of corrupted packets.
The fact that the same switch worked with the previous router suggests that the problem is probably more likely to be a configuration issue with the new hEX router.
What has changed?
  • ISP
  • Cable Modem/router
  • Anything else?
Is the Cable modem now in true bridge mode, or is it still the Cable Modem/Router (what type, and what ISP?). Is the modem/router in passthrough mode? I have seen many problems reported with passthrough on ATT (especially PACE modems).
What feature of the hEX encouraged you to replace the integrated router in the cable modem? Are you now using vlans?
What speed is your cable service?
DeltaCreek
Tue Jun 21, 2022 1:26 am
I'm on Virgin Media in the UK using the Hub 3.0. I'm not sure what kind of connection the device has to the Mikrotik router when it's in modem mode. I enabled the DHCP client on the Mikrotik router and everything appeared to go well from there.
I removed the Mikrotik router from the network and re-enabled the Virgin device in router mode. Everything seems a lot smoother. For example, I set up some basic internet monitoring on a Raspberry Pi and this is the result when Mikrotik was the router:
Jun 20 22:14:51 check[82639]: netcat succeeded
Jun 20 22:14:51 check[82641]: PING google.com (142.250.200.14) 56(84) bytes of data.
Jun 20 22:14:54 check[82641]: --- google.com ping statistics ---
Jun 20 22:14:54 check[82641]: 3 packets transmitted, 1 received, 66.6667% packet loss, time 2061ms
Jun 20 22:14:54 check[82641]: rtt min/avg/max/mdev = 29.474/29.474/29.474/0.000 ms
While netcat succeeded, ping reported packet loss every time (every 30 seconds). With the Virgin Router, there is no packet loss at all.
Jun 20 23:21:03 check[1564]: netcat succeeded
Jun 20 23:21:03 check[1566]: PING google.com (142.250.187.206) 56(84) bytes of data.
Jun 20 23:21:05 check[1566]: --- google.com ping statistics ---
Jun 20 23:21:05 check[1566]: 3 packets transmitted, 3 received, 0% packet loss, time 2003ms
Jun 20 23:21:05 check[1566]: rtt min/avg/max/mdev = 14.177/18.291/24.148/4.253 ms
I like what I saw with the Mikrotik router. I originally got it because my Unifi network application changed IP addresses and I had some difficulty communicating that with the Flex Mini switch. There is a recovery mode where the switch checks for firmware on a static route, however I was unable to use that subnet with the Virgin router. Hence the Mikrotik.
Do you think this is a configuration problem or something to do with the router's modem mode? How would you recommend I debug the issue?
DeltaCreek
Tue Jun 21, 2022 10:35 am
The network has been rock solid since reverting back to router mode and removing the Mikrotik device. I don't know how Ubiquiti calculates its WiFi score, but the stability is evident in the graphs from the two access points.
I hope I the router won't go to waste but I'm not sure yet how to diagnose what's going wrong.
erlinden
Tue Jun 21, 2022 10:49 am
Can you please share your hEX S config (/export file=anynameyoulike) don't forget to remove any personal information?
Do you have any static IP addresses configured?
What is the purpose of the MikroTik router (just curious)?
Buckeye
Forum Veteran
Forum Veteran
Thu Jun 23, 2022 12:05 pm
I have Unifi Access points at home, but don't use any Unifi (or any Ubiquiti, e.g. edgemax) switches, I have a mutt network of MikroTik, TP-Link, and Netgear vlan-aware switches, plus multiple "dumb" switches (TP-Link, TrendNet, even a bottom of the barrel Tenda 5 port 1Gbps). My main home router is a Ubiquiti ER-X and I have a "lab" with several ER-X's and an RB760iGS. I use a Raspberry Pi running the UniFi controller software instead of a UniFi CloudKey for the UniFi Controller.
Since I don't have any UniFi switches, I can't give you any first hand experience there, but I would have thought all you would have needed to do would be editing the network, but in worst case, using reset button on the flex mini switch, and then readopting in the new network.
As far as what in causing problems, I don't have one, but the Super Hub 3 is on this list of modems to avoid (due to it being based on the arguably defective Puma 6 chipset). Just do a google search of "puma 6" to see what I mean.
DeltaCreek
Fri Jun 24, 2022 10:39 am
I got the router because I moved my Unifi network application so a new server and the switch could no longer communicate with it. I tried the available adoption methods but they weren't working. I wanted to try the recovery method for the switch and it requires a server running on 192.168.1.99. That subnet is reserved on the Virgin router so I got the Mikrotik. Plus, it's fun.
This is my configuration
# jun/20/2022 22:13:35 by RouterOS 6.49.6
# software id = 87J3-A1J9
# model = RB760iGS
# serial number = <redacted>
add admin-mac=18:FD:74:07:D6:C6 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-server option
add code=43 name=unifi value=<redacted>
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=sfp1
add address=192.168.1.1/24 comment=defconf interface=ether2 network=\
    192.168.1.0
/ip cloud
set ddns-update-interval=1m
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.10 client-id=1:e0:63:da:2a:36:f1 mac-address=\
    E0:63:DA:2A:36:F1 server=defconf
add address=192.168.1.20 client-id=1:e4:5f:1:c2:f2:13 mac-address=\
    E4:5F:01:C2:F2:13 server=defconf
add address=192.168.1.11 client-id=1:b4:fb:e4:2e:14:3e mac-address=\
    B4:FB:E4:2E:14:3E server=defconf
add address=192.168.1.12 mac-address=74:83:C2:FA:D5:3D server=defconf
add address=192.168.1.0/24 comment=defconf dns-server=192.168.1.1 gateway=\
    192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip ssh
set always-allow-password-login=yes
/system clock
set time-zone-name=Europe/London
/system leds
set 0 disabled=yes
/tool e-mail
set address=<redacted>
/tool mac-server
/tool mac-server mac-winbox
Users browsing this forum: Amazon [Bot] and 30 guests
