Treart
Inter VLAN routing not working
Mon Jun 20, 2022 5:08 pm
Hello guys,
I'm having trouble reaching the devices on VLAN12 from a service PC that resides on VLAN11. I can reach the devices on all other VLANS from this PC (like unifi switches that are on VLAN10, ecc...).
I have rules in the firewall to block all access from VLAN13 (a guest reserved VLAN for external users) to other VLANs, but even if I disable these rules the problem is still there.
As you see I have used mangle to create a static route/rule because this customer has 2 internet routers (an optic fiber for normal internet access and a backup ADSL on which I have routed the VoIP traffic from the VLAN12 with said mangle, reserved for IP phones connected to a cloud pbx)
I hope I made myself clear. Here is my config
# jun/20/2022 15:58:20 by RouterOS 6.47.8
# software id = UDB2-X12K
# model = 2011iL
# serial number = 7DCF073A6FC2
add admin-mac=6C:3B:6B:D6:0F:52 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=6C:3B:6B:D6:0F:51
set [ find default-name=ether2 ] mac-address=6C:3B:6B:D6:0F:52
set [ find default-name=ether3 ] disabled=yes mac-address=6C:3B:6B:D6:0F:53
set [ find default-name=ether4 ] disabled=yes mac-address=6C:3B:6B:D6:0F:54
set [ find default-name=ether5 ] mac-address=6C:3B:6B:D6:0F:55
set [ find default-name=ether6 ] disabled=yes mac-address=6C:3B:6B:D6:0F:56
set [ find default-name=ether7 ] disabled=yes mac-address=6C:3B:6B:D6:0F:57
set [ find default-name=ether8 ] disabled=yes mac-address=6C:3B:6B:D6:0F:58
set [ find default-name=ether9 ] mac-address=6C:3B:6B:D6:0F:59
set [ find default-name=ether10 ] disabled=yes mac-address=6C:3B:6B:D6:0F:5A
/interface vlan
add interface=ether5 name=VLAN10_MGMT vlan-id=10
add interface=ether5 name=VLAN11_Uffici vlan-id=11
add interface=ether5 name=VLAN12_Telefoni vlan-id=12
add interface=ether5 name=VLAN13_Guest vlan-id=13
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.100-192.168.88.200
add name=MGMT_pool ranges=192.168.10.50-192.168.10.250
add name=uffici_pool ranges=192.168.0.50-192.168.0.250
add name=TELEFONI_pool ranges=192.168.12.50-192.168.12.250
add name=GUEST_pool ranges=192.168.13.50-192.168.13.250
add name=OVPN_pool ranges=192.168.30.100-192.168.30.200
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add address-pool=MGMT_pool disabled=no interface=VLAN10_MGMT name=vlan10_dhcp
add address-pool=uffici_pool disabled=no interface=VLAN11_Uffici name=\
vlan11_dhcp
add address-pool=TELEFONI_pool disabled=no interface=VLAN12_Telefoni name=\
vlan12_dhcp
add address-pool=GUEST_pool disabled=no interface=VLAN13_Guest name=\
vlan13_dhcp
/ppp profile
add local-address=192.168.10.1 name=ovpn_fidia remote-address=OVPN_pool
/queue simple
add max-limit=2M/10M name=Test_2 queue=ethernet-default/ethernet-default \
target=10.10.13.0/24
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add interface=ether2 list=WAN
/interface ovpn-server server
set certificate=server cipher=blowfish128,aes128,aes192,aes256 enabled=yes \
port=11940 require-client-certificate=yes
192.168.88.0
add address=192.168.0.1/24 interface=VLAN11_Uffici network=192.168.0.0
add address=192.168.10.1/24 interface=VLAN10_MGMT network=192.168.10.0
add address=192.168.12.1/24 interface=VLAN12_Telefoni network=192.168.12.0
add address=192.168.13.1/24 interface=VLAN13_Guest network=192.168.13.0
/ip dhcp-client
add comment=defconf default-route-distance=2 disabled=no interface=ether1
add disabled=no interface=ether2
/ip dhcp-server lease
add address=192.168.0.70 client-id=1:f4:2:70:aa:de:ae mac-address=\
F4:02:70:AA:DE:AE server=vlan11_dhcp
add address=192.168.0.102 client-id=1:98:ee:cb:75:aa:44 mac-address=\
98:EE:CB:75:AA:44 server=vlan11_dhcp
add address=192.168.0.0/24 comment=UFFICI dns-server=8.8.8.8,8.8.4.4 gateway=\
192.168.0.1
add address=192.168.10.0/24 comment=MGMT dns-server=8.8.8.8,8.8.4.4 gateway=\
192.168.10.1
add address=192.168.12.0/24 comment=TELEFONI dns-server=8.8.8.8,8.8.4.4 \
gateway=192.168.12.1
add address=192.168.13.0/24 comment=GUEST dns-server=8.8.8.8,8.8.4.4 gateway=\
192.168.13.1
add address=192.168.30.0/24 gateway=192.168.30.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
established,related,untracked
invalid
add action=accept chain=input comment=WinBox in-interface=VLAN11_Uffici
add action=accept chain=input comment=OVPN dst-port=11940 in-interface=ether2 \
protocol=tcp
add action=accept chain=input comment=WinBox_WAN dst-port=8291 in-interface=\
ether2 protocol=tcp
add action=drop chain=forward in-interface=VLAN13_Guest out-interface=\
VLAN11_Uffici
VLAN12_Telefoni
VLAN10_MGMT
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes
connection-state=invalid
/ip firewall mangle
add action=mark-routing chain=prerouting in-interface=VLAN12_Telefoni \
new-routing-mark=to_Fastweb passthrough=yes
add action=dst-nat chain=dstnat comment="UltraVNC Ilaria" dst-port=6688 \
in-interface=ether2 protocol=tcp to-addresses=192.168.0.102 to-ports=6688
add distance=1 gateway=192.168.1.1 routing-mark=to_Fastweb
/ppp secret
add name=martina profile=ovpn_fidia service=ovpn
add name=nicola profile=ovpn_fidia service=ovpn
add name=andrea profile=ovpn_fidia service=ovpn
add name=kyle profile=ovpn_fidia service=ovpn
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=FIDIA
/tool mac-server
/tool mac-server mac-winbox
Buckeye
Forum Veteran
Forum Veteran
Re: Inter VLAN routing not working
Mon Jun 20, 2022 10:04 pm
I am a noob with ROS firewalls, but I think you need to add your vlan interfaces to your LAN member list, unless you want to treat each vlan with its own firewall rules.
i.e. I think this rule is causing the packets from vlan 12 to vlan 11 to be dropped.
On possible fix given:
/interface vlan
add the bold part to the following stanza
add interface=VLAN11_Uffici list=LAN
add interface=VLAN12_Telefoni list=LAN
Treart
Tue Jun 21, 2022 3:42 pm
Tried adding the two VLAN interfaces to the LAN list but still not working, unable to reach the IP phones from VLAN11
mkx
Tue Jun 21, 2022 5:02 pm
If I read the config correctly ... then you have some kind of VLAN-aware switch connected to ether5, which is configured as a trunk port? There is no firrwall rule blocking traffic between said VLANs so you'll have to verify that packets intended to flow between both VLANs actually reach your router both ways (if there's a routing triangle in your network, then packets would be dropped by rule add action=drop chain=forward comment="defconf: drop invalid" connection-state=invalid (what does counter for this rule say, anything hitting it?).
And the other thing (often forgotten by people): make sure OS firewalls allow connections from IP subnets other than own (windows firewall by default doesn't).
Treart
Tue Jun 21, 2022 5:14 pm
Yes I have Unifi switches in this network, and the port connected to Ether5 is a trunk port, allowing all VLANS to enter. The weird thing is that from this "service PC" residing on VLAN11 I can enter the Unifi devices via SSH (they reside on VLAN10_MGMT) without problems, so it looks that interVLAN routing works!
I'll check the log for the rule you mentioned, and this comes out:
forward: in:VLAN12_Telefoni out:ether1, src-mac 0c:38:3e:44:0f:fd, proto TCP (SYN,ACK), 192.168.12.246:80->192.168.0.68:62142, len 52
192.168.12.246 is an IP phone, 192.168.0.68 is the service PC
Tried disabling the rule to no avail. I'm going crazy.
mkx
Tue Jun 21, 2022 5:38 pm
Above that rule add a rule something like this one:
add chain=forward action=log src-address=192.168.0.68 dst-address=192.168.12.246
It should show fou if forward teaffic is passing your router as well, the packet you showed is first return packet actually and it's extremely suspicious to see it marked as invalid. The only explanation would be that the initial (forward) packet bypasses router/firewall.
Treart
Tue Jun 21, 2022 5:44 pm
Tried this and the log shows "forward: in:VLAN11_Uffici out:VLAN12_Telefoni, src-mac 00:0c:29:58:ae:b1, proto TCP (SYN), 192.168.0.68:62345->192.168.12.246:80, len 52"
mkx
Tue Jun 21, 2022 5:50 pm
There's your routing problem:
So forward packet enters router through VLAN11_Ufici and leaves through VLAN12_Telefoni. Return packet enters through VLAN12_Telefoni but leaves through ether1.
I'm not a mangle expert, but there might be some problem there ...
It says everything (no exceptions) from phone VLAN should use to_Fastweb routing table.
Treart
Tue Jun 21, 2022 5:54 pm
Could be, I didn't think of that. I have that mangle to mark packets from phones to be routed through the backup ADSL line instead of the optic fiber.
i just tried disabling it, and magically I could reach the IP phones.
Thanks for the help guys, appreciate it.
Users browsing this forum: glat, Google [Bot], rplant and 124 guests
