antiqued4
Help with quotes and variables
Mon Jun 20, 2022 5:40 pm
Hi guys, someone who understands script there if you can help me, I need to run a script that contains quotes within variables.
if I leave it in this format, it gives an error in the first quote
\n/tool ​​e-mail send body="$linkname is online subject=Test to=demailtest@test.com\r\
Now if I do it this way:
\n/tool ​​e-mail send body=\"$linkname is online" subject=Test to=demailtest@teste.com\r\
It gives Error in the first s there of the subject
If I leave it in this format below, it adds the variable and the text, but without the quotes it doesn't work
\n/tool ​​e-mail send body=\$linkname is online subject=Test to=demailtest@test.com\r\
I would need to add both the variable and the text but everything in quotes, does anyone know how? would have to stay like this
/tool ​​e-mail send body="$linkname is online" subject=Test to=demailtest@test.com
mrz
Re: Help with quotes and variables
Mon Jun 20, 2022 6:36 pm
antiqued4
Mon Jun 20, 2022 7:20 pm
I tried it in several ways unfortunately or it emits the variable, or the variable already comes with a value
mrz
Re: Help with quotes and variables  [SOLVED]
Mon Jun 20, 2022 7:57 pm
"some string and \"string withing string $variable continued\" end"
antiqued4
Mon Jun 20, 2022 8:15 pm
I got it, thanks a lot, here's an example below of how I did it in case it helps someone
body=\"\$string is online\"
Users browsing this forum: No registered users and 56 guests
