sieacara
Graphing (192.168.1.1/graphs) does not match the data on mikrotik
Mon Jun 20, 2022 10:08 pm
Hi everyone
I have a problem with the graphing tool on MikroTik, when I check directly into MikroTik the graphing tool is still running and stored and displays current and previous graphs, but on the website display (192.x.x.x/graphs) the traffic that passes is stopped and does not continue today/week/month next.
here the website display
here the webfig (website) display
anyone know this problem?
Thank you for your help first
joegoldman
Forum Veteran
Forum Veteran
Re: Graphing (192.168.1.1/graphs) does not match the data on mikrotik  [SOLVED]
Tue Jun 21, 2022 1:37 am
the data in the graph itself appears correct comparing 1:1 (webfig vs basic page), it may just be a visual time bug. I can assume the time is set correctly since webfig looks correct, but maybe try re-setting the time (timezone is correct, us an NTP server) and if that doesn't help see if its still an issue after a reboot.
I'd say the graph display page is just working off the wrong 'time' (and date), but as said the graphs seem to match-up almost perfectly in display.
sieacara
Fri Jun 24, 2022 5:50 am
Thanks man
The problem is my mikrotik date stop at 30 May (i dont know why, maybe NTP server error or something)
So i just set second NTP server on my mikrotik then Mikrotik date back to actual date and graphing graph back to normal.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], loloski, Majestic-12 [Bot] and 94 guests
