gotsprings
Zerotier behavior change in 7.3.1
Tue Jun 21, 2022 1:46 am
I am now noticing in RouterOS 7.3.1 Zerotier is not "getting an IP" on the interface any longer.
For instance...
The site I am connecting to is 192.168.1.1/24
I have the hAP AC2 set in myzerotier to get 192.168.1.30/23
Since the update to 7.3.1... it does not show that IP address on the Zerotier interface.
Zerotier shows the hAP AC2 as online and I can REACH THE HAPAC2 at 192.168.1.1
I have another site with a RB3011 that doesn't seem to want to connect to zerotier.
its status shows as Requesting... but I don't see any traffic on that interface. or on port 9993 on the router.
gotsprings
Re: Zerotier behavior change in 7.3.1  [SOLVED]
Tue Jun 21, 2022 10:05 pm
allow-managed
Will get the IP address to show up... after you disable and reenable the instance.
Users browsing this forum: trmns and 45 guests
