jaxed8
Access winbox remotely over VPN
Tue Jun 21, 2022 12:45 pm
Hello everyone
I want to access my router through winbox over the internet, so I setup a L2TP VPN on the router and wrote down the local IP that the VPN server gave the router and on the other device (on the internet), which is connected to the same VPN server and is within the same subnet trying to access the router with winbox but got the error that is saying the connection timed out.
P.S. I use the following rule in router /firewall nat and also I change the default winbox port.
Nat rule: add action=dst-nat chain=dstnat comment="Remote winbox" disabled=no dst-port=\
1111 log=yes log-prefix="Remote winbox" protocol=tcp to-addresses=\
192.168.88.1 to-ports=9999
I try to connect to router by using 192.168.5.6 (router IP on VPN server subnet):1111
jaxed8
Re: Access winbox remotely over VPN
Wed Jun 22, 2022 7:02 am
Anyone? :?
gotsprings
Wed Jun 22, 2022 12:44 pm
If you got your VPN right... Nat is not involved with reaching winbox.
That would be an INPUT RULE matching the interface or subnet of your VPN CLIENT.
gemesif
Wed Jun 22, 2022 2:27 pm
ping is working, from VPN client to 192.168.5.6?
I think, NAT rule is good...
jaxed8
Wed Jun 22, 2022 2:28 pm
Still the same even after adding the input rule for VPN interface.
Actually after adding the rule I got hit on the rule and packets count but still the same connection timed out error.
jaxed8
Wed Jun 22, 2022 2:35 pm
@gamesif
No pinging the private IP address of the router on the VPN subnet is not working.
P.S. Both of my devices (router - windows) are clients of a VPN server that I don't have access to server (I think it's Nord).
jaxed8
Wed Jun 22, 2022 5:15 pm
There is no difference even when using /ip cloud
gemesif
Wed Jun 22, 2022 7:20 pm
The side from which you want to connect with winbox, need to know two things from a routing aspect.
- routing 'internet access' to VPN provider IP address
- routing 'L2TP VPN access' to l2tp tunnel IP on this side
What shows?
(in Windows command prompt)
route print
tracert 192.168.5.6
jaxed8
Wed Jun 22, 2022 11:43 pm
@gemesif
172.19.19.45 is the router I want to connect to. (was 192.168.5.6 but I change the VPN server so it's 172.19.19.45 now)
Here you go:
with 172.19.19.45:
with Mikrotik /ip cloud DDNS:
with /ip cloud DDNS it's not connecting to winbox too, but I had the same setup some where else but with static public IP and I could easily connect to the router with winbox.
gemesif
Thu Jun 23, 2022 11:47 pm
I think we need to find a solution in this direction:
https://docs.microsoft.com/en-us/window ... pn-routing
"Network routes are required for the stack to understand which interface to use for outbound traffic. One of the most important decision points for VPN configuration is whether you want to send all the data through VPN (force tunnel) or only some data through the VPN (split tunnel). This decision impacts the configuration and the capacity planning, as well as security expectations from the connection."
jaxed8
Re: Access winbox remotely over VPN  [SOLVED]
Sat Jul 30, 2022 11:20 pm
It was a problem with Nord VPN network.
Thank you guys
rextended
Sun Jul 31, 2022 3:53 am
Please explain me why you censore private IP addresses...
Is better you understand the differencies between public and private IP space...
cmd code
C:\Users\RexTended>route print
Elenco interfacce
 13...08 60 6e 90 22 e4 ......Intel(R) 82579V Gigabit Network Connection
  6...08 60 6e f2 d6 6a ......Intel(R) 82574L Gigabit Network Connection
  1...........................Software Loopback Interface 1
IPv4 Tabella route
Route attive:
     Indirizzo rete             Mask          Gateway     Interfaccia Metrica
          0.0.0.0          0.0.0.0   192.168.11.254    192.168.11.11     25
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    331
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    331
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    331
     192.168.11.0    255.255.255.0         On-link     192.168.11.11    281
    192.168.11.11  255.255.255.255         On-link     192.168.11.11    281
   192.168.11.255  255.255.255.255         On-link     192.168.11.11    281
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    331
        224.0.0.0        240.0.0.0         On-link     192.168.11.11    281
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    331
  255.255.255.255  255.255.255.255         On-link     192.168.11.11    281
Route permanenti:
  Nessuna
Users browsing this forum: Bing [Bot], GoogleOther [Bot], homerouter, Majestic-12 [Bot], Paltri34, vingjfg and 141 guests
