Recently my ping went up and speeds are wonky.
All following results are from the same speedtest server and the same speedtest node for consistency:
So in the morning, my ping and speeds were great with fasttrack enabled and basically what I would expect with this internet provider. But now at the evening, my ping is much higher and download speed is very slow with enabled fasttrack, when I disable fasttrack, it fixes the upload speed, but lowers my download speed (presumably because of higher CPU usage) and the ping is still kind of high.
Weird thing is that I did not change any settings on my Mikrotik so I'm really confused as to what is actually happening. Could it be some misconfiguration or could it be related to the switch? Can somebody explain this mystery to me?
This is export from my firewall filter rules:
Code: Select all
Flags: X - disabled, I - invalid; D - dynamic
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept in ipsec policy
chain=forward action=accept log=no log-prefix="" ipsec-policy=in,ipsec
2 ;;; defconf: accept out ipsec policy
chain=forward action=accept log=no log-prefix="" ipsec-policy=out,ipsec
3 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related log=no log-prefix=""
4 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked log=no log-prefix=""
5 chain=input action=accept connection-state=established log=no log-prefix=""
6 chain=input action=accept connection-state=related log=no log-prefix=""
7 chain=input action=accept protocol=icmp limit=5,5:packet log=no log-prefix=""
8 ;;; MS multiplayer
chain=forward action=accept protocol=udp dst-port=88,3074,53,500,3544,4500,52684,524 log=no log-prefix=""
9 ;;; MS multiplayer
chain=forward action=accept protocol=tcp dst-port=3070,53 log=no log-prefix=""
10 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid log=no log-prefix=""
11 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN log=no log-prefix=""
12 chain=input action=drop in-interface-list=!LAN log=no log-prefix=""
Code: Select all
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no log-prefix="" ipsec-policy=out,none
1 chain=srcnat action=masquerade out-interface=BSC log=no log-prefix=""
2 ;;; HA TCP
chain=dstnat action=dst-nat to-addresses=192.168.0.100 to-ports=443 protocol=tcp in-interface-list=WAN dst-port=443,80 log=no log-prefix=""
3 ;;; HA UDP
chain=dstnat action=dst-nat to-addresses=192.168.0.100 to-ports=443 protocol=udp in-interface-list=WAN dst-port=443,80 log=no log-prefix=""
4 ;;; RDP TCP
chain=dstnat action=dst-nat to-addresses=192.168.0.10 to-ports=3389 protocol=tcp in-interface-list=WAN dst-port=3390 log=no log-prefix=""
5 ;;; RDP UDP
chain=dstnat action=dst-nat to-addresses=192.168.0.10 to-ports=3389 protocol=udp in-interface-list=WAN dst-port=3390 log=no log-prefix=""
6 ;;; ARK
chain=dstnat action=dst-nat to-addresses=192.168.0.12 protocol=tcp in-interface-list=WAN dst-port=27000-27031,27036-27037,25147 log=no log-prefix=""
7 ;;; ARK
chain=dstnat action=dst-nat to-addresses=192.168.0.12 protocol=udp in-interface-list=WAN dst-port=27000-27031,25147,27015,27036,7777-7778,4380 log=no log-prefix=""
8 ;;; MC server
chain=dstnat action=dst-nat to-addresses=192.168.0.12 protocol=udp in-interface-list=WAN dst-port=25565 log=no log-prefix=""
9 ;;; MC server
chain=dstnat action=dst-nat to-addresses=192.168.0.12 protocol=tcp in-interface-list=WAN dst-port=25565 log=no log-prefix=""
Code: Select all
Flags: X - disabled, I - invalid; R - running
0 R name="internet_T-mobile" max-mtu=auto max-mru=auto mrru=disabled interface=[1] WAN ether user="REDACTED" password="REDACTED" profile=default
keepalive-timeout=10 service-name="" ac-name="" add-default-route=yes default-route-distance=1 dial-on-demand=no use-peer-dns=yes allow=pap,chap,mschap1,mschap2
Code: Select all
# LIST INTERFACE
;;; defconf
0 LAN bridge
;;; defconf
1 WAN internet_T-mobile
2 WAN [1] WAN ether
