zorger
Advanced Netwatch
Wed Jun 22, 2022 11:38 am
Hi!
I'm writing some simple netwatch code to monitor some network device state with mikrotik NetWatch and telegram.
netwatch
up:
/tool fetch url="telegram bot get api url with message - link up" keep-result=no
down:
/tool fetch url="telegram bot get api url with message - link down" keep-result=no
config:
ip = some ip
interval = 60 sec
timeout = 5 sec
and all work, but it to often send me message, because of 1 ping packet droped in a minute when it check connection.
now i rewrite it, with
down
:if ([/ping IP interval=1 count=10] = 0) do={
up
:if ([/ping IP interval=1 count=10] != 0) do={
And now it send message about down only if realy down, more than 10 seconds.
But it stay to often send about link UP.
How properly solve this case?
Jotne
Re: Advanced Netwatch
Wed Jun 22, 2022 2:01 pm
I do use same script for both up and down in netwatch.
viewtopic.php?p=888800#p888800
You can just change :log to telegram
eworm
Wed Jun 22, 2022 5:18 pm
Or have a look at my scripts, especially Notify on host up and down.
zorger
Sat Jun 25, 2022 4:59 pm
Thanks to all! I make decision to write code in netwatch up/down, without script
Prepare:
:global filename "hcoreisup.txt"
/file print file=$filename where name=""
/file set $filename contents="UP"
UP code:
:global hcoreisup ""
:global hcoreisup [/file get $filename contents];
:if ($hcoreisup="") do={ log/info message="hcoreisup not defined"
	:if ([/ping 172.16.33.1 interval=1 count=10] = 0 ) do={ :global hcoreisup "DOWN" } else={ :global hcoreisup "UP" }
	  :delay 1
	  /file set $filename contents=$hcoreisup
	  log/info message=$hcoreisup
} else={ :if ($hcoreisup="DOWN") do={:if ([/ping 172.16.33.1 interval=1 count=10] = 0 ) do={:global hcoreisup "DOWN"} else={ :global hcoreisup "UP"
/tool fetch url="https://api.telegram.org/BOT_API_KEY/sendMessage\?chat_id=-CHAT_1_ID&text=URLENCODED_TEXT" keep-result=no
/tool fetch url="https://api.telegram.org/BOT_API_KEY/sendMessage\?chat_id=-CHAT_2_ID&text=URLENCODED_TEXT" keep-result=no
				log/info message=$hcoreisup } } else={ log/info message=$hcoreisup } }
DOWN code:
		:delay 1
} else={ :if ($hcoreisup="UP") do={:if ([/ping 172.16.33.1 interval=1 count=10] = 0 ) do={ :global hcoreisup "DOWN"
Jotne
Sat Jun 25, 2022 9:21 pm
You do not need two script. Use same script for both up/down and then use the status variable to see if its up/down as I already posted above:
Any reason for using global variable in the script? Use local variable if you do not intend to store the data for later use or use in another script.
Users browsing this forum: No registered users and 17 guests
