zlatkomajstor
Problem with Wi-Fi network on RBD52G-5HacD2HnD
Wed Jun 22, 2022 11:59 am
I have problem with the Wi-Fi network when trying to connect to the Mikrotik from a laptop with Ubuntu OS.
I have tried with different settings on the Mikrotik but no change.
This is the output for Wi-Fi Country and enabled channels when connecting to the Mikrotik:
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, PASSIVE-SCAN
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, PASSIVE-SCAN
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, PASSIVE-SCAN
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, PASSIVE-SCAN
(5735 - 5835 @ 80), (N/A, 20), (N/A), PASSIVE-SCAN
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
country ID: DFS-UNSET
(2402 - 2437 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-80MHZ, NO-160MHZ
(2422 - 2462 @ 40), (6, 22), (N/A), AUTO-BW, NO-80MHZ, NO-160MHZ
(2447 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5735 - 5815 @ 20), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
wlo1 17 channels in total; available frequencies :
Channel 01 : 2.412 GHz
Channel 02 : 2.417 GHz
Channel 03 : 2.422 GHz
Channel 04 : 2.427 GHz
Channel 05 : 2.432 GHz
Channel 06 : 2.437 GHz
Channel 07 : 2.442 GHz
Channel 08 : 2.447 GHz
Channel 09 : 2.452 GHz
Channel 10 : 2.457 GHz
Channel 11 : 2.462 GHz
Channel 12 : 2.467 GHz
Channel 13 : 2.472 GHz
Channel 149 : 5.745 GHz
Channel 153 : 5.765 GHz
Channel 157 : 5.785 GHz
Channel 161 : 5.805 GHz
Current Frequency:5.745 GHz (Channel 149)
As you can see only 4 channels available on the 5GHz network.
This is what I get when connecting to another Wi-Fi that it's not Mikrotik:
global
country DE: DFS-UNSET
(5170 - 5190 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5190 - 5210 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5210 - 5230 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, PASSIVE-SCAN
(5230 - 5250 @ 160), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, PASSIVE-SCAN
(5250 - 5270 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5270 - 5290 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5290 - 5310 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5310 - 5330 @ 160), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5490 - 5510 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5510 - 5530 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5530 - 5550 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5550 - 5570 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5570 - 5590 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5590 - 5610 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5610 - 5630 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, PASSIVE-SCAN
(5630 - 5650 @ 240), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, PASSIVE-SCAN
(5650 - 5670 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5670 - 5690 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5690 - 5710 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40MINUS, NO-160MHZ, PASSIVE-SCAN
(5710 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5755 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5755 - 5775 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5775 - 5795 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-160MHZ
(5795 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-160MHZ
(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
wlo1 32 channels in total; available frequencies :
Channel 36 : 5.18 GHz
Channel 40 : 5.2 GHz
Channel 44 : 5.22 GHz
Channel 48 : 5.24 GHz
Channel 52 : 5.26 GHz
Channel 56 : 5.28 GHz
Channel 60 : 5.3 GHz
Channel 64 : 5.32 GHz
Channel 100 : 5.5 GHz
Channel 104 : 5.52 GHz
Channel 108 : 5.54 GHz
Channel 112 : 5.56 GHz
Channel 116 : 5.58 GHz
Channel 120 : 5.6 GHz
Channel 124 : 5.62 GHz
Channel 128 : 5.64 GHz
Channel 132 : 5.66 GHz
Channel 136 : 5.68 GHz
Channel 140 : 5.7 GHz
Current Frequency:5.18 GHz (Channel 36)
As you can see many more frequencies enabled and the country code is DE.
I tried with different settings on the Mikrotik but I can't get more than those 4 frequencies. Also country code is never set although I have tried setting different countries in the Mikrotik.
mkx
Re: Problem with Wi-Fi network on RBD52G-5HacD2HnD
Wed Jun 22, 2022 4:00 pm
Post config of your hAP ac2: open terminal window, execute command /interface wireless export hide-sensitive file=anynameyouwish, fetch resulting file, open it in text editor, obfuscate any remaining sensitive information (such as WiFi password or device serial number) and copy-paste it here inside [code] [/code] environment.
zlatkomajstor
Thu Jun 23, 2022 8:39 pm
# jun/23/2022 19:35:25 by RouterOS 7.3.1
# software id = GH4Q-97IU
# model = RBD52G-5HacD2HnD
# serial number = xxx
add authentication-types=wpa-psk,wpa2-psk eap-methods="" mode=dynamic-keys \
    name=profile1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=\
    20/40mhz-XX country=no_country_set disabled=no distance=indoors \
    frequency=auto frequency-mode=manual-txpower mode=ap-bridge \
    security-profile=profile1 ssid=xxx_2GHz station-roaming=\
    enabled wireless-protocol=802.11
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-a/n/ac \
    channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no \
    distance=indoors frequency=5745 frequency-mode=manual-txpower mode=\
    ap-bridge security-profile=profile1 ssid=xxx_5GHz \
    station-roaming=enabled wireless-protocol=802.11
pe1chl
Thu Jun 23, 2022 10:11 pm
You have set the 5G wifi to "indoors", that makes it avoid DFS channels.
When you want to use a DFS channel, set it to "any".
Also, you have not successfully set a country. Note that when you change country, it may tell you that some other parameter is unacceptable. You need to change that parameter AND change the country in one go.
zlatkomajstor
Thu Jun 23, 2022 10:24 pm
Already tried to use different countries as I wrote in the first topic. Nothing changed.
Installation type is set to any:
pe1chl
Fri Jun 24, 2022 12:16 am
Then please show your new export made after you have made those changes!
bpwl
Fri Jun 24, 2022 1:28 am
So many things that can go wrong with these settings.
antenna gain=0 -> illegal, minimum is 3 for hAP ac2 (country will not be accepted if too low)
no_country_set = FCC (USA) frequencies only! And that is a limited set !
2.4GHz 40MHz-XX = interference all over the spectrum
frequency=auto , you never know what you will get
5GHz 80MHz-XXXX = very undefined , and maybe just not possible for FCC
If freq is possible you might have a wheater radar frequency is this broad band, and then 5 GHz will be dead for at least 10 minutes after every change.
distance=indoors ("distance" is NOT" installation"!)
"_" in SSID can give problems. : viewtopic.php?t=184427
Users browsing this forum: No registered users and 45 guests
