vittore
netbox and napalm
Wed Jun 22, 2022 2:07 pm
Someone is using netbox and napalm with Mikrotik devices?
https://docs.netbox.dev/en/stable/
https://github.com/napalm-automation/napalm
dbenitesi
Re: netbox and napalm
Mon Jul 11, 2022 1:42 am
am starting to try, let u know what happend, and am trying to get mikotik ---> Netbox ---> zabbix
k6ccc
Mon Jul 11, 2022 3:34 am
The subject made me laugh. What the heck was he trying to do with gelled gasoline?
Never heard of a software product called napalm...
hawkn
Thu Feb 23, 2023 3:21 pm
I'm bumping this, anyone have an update ?
I've installed NetBox, I have Graylog and Zabbix also installed.
I want to get some automation in play rather than manually inputing ports, VLANs, IP adresses and such into NetBox.
My equipment is cisco switches, mikrotik RB5009, RB2011iL, RB450G, hAP AX2 and hAP AC3 routers. (hAP-s are used as Accesspoints here and there)
What I want to do first, is to scan all ports and such on all devices in some way and get them into NetBox, serial numbers and IP adresses, hostnames etc.
txfz
Thu Feb 23, 2023 5:02 pm
Well, I have it set up for reading configuration. Not yet for saving it to NetBox.
vittore
Thu Feb 23, 2023 5:23 pm
There isn't news in my configuration.
v.
gt732
Fri Jun 23, 2023 3:48 pm
I've done this using a custom python script to extract the info I needed from the mikrotik api then pushing it to netbox via their api. I think I used the routeros library, I will have to go back and check.
LunaticRv
Mon Jun 26, 2023 10:10 pm
Hello, it would be really nice if you could share the script you have used. I am trying to automate extracting the data but no luck so far
Users browsing this forum: Amazon [Bot], Bing [Bot] and 118 guests
