The ISP is fastweb (mixed fiber 100/100) which provides me with 5 public IP addresses and which I have assigned to each port to differentiate some services.
Since Vodafone arrives in direct fiber at 1000/200 I would like to connect it to eth7 as WAN_2 and divert all traffic from the LAN to it and leave VOIP and the 3 SERVER on WAN_1.
I researched for hours and I realized that you need to create 2 mangle rules (one for FASTWEB and one for VODAFONE) where the packets are marked, assign them to 2 routing tables and then modify the route by assigning the tables for the two connections.
Unfortunately despite all attempts I was unable to get the configuration to work.
Could anyone kindly help me?
Thanks in advance,
Gianluca
the current configuration without mangle rules is as follows:
Code: Select all
# jun/22/2022 13:59:29 by RouterOS 7.2.3
# model = CCR1009-7G-1C-1S+
add name=BRIDGE_LAN
add name=BRIDGE_SERVER
set [ find default-name=combo1 ] name=WAN_ISP1
set [ find default-name=ether1 ] name=LAN
set [ find default-name=ether2 ] name=VOIP
set [ find default-name=ether3 ] name=SERVER1
set [ find default-name=ether4 ] name=SERVER2
set [ find default-name=ether5 ] name=SERVER3
set [ find default-name=ether7 ] name=WAN_ISP2
set [ find default-name=sfp-sfpplus1 ] name=SFPPLUS
add name=dhcp_lan_pool ranges=192.168.98.100-192.168.98.254
add address-pool=dhcp_lan_pool interface=BRIDGE_LAN name=dhcp_lan
/routing table
add disabled=no fib name=TO_VODA
add disabled=no fib name=TO_FAST
add bridge=BRIDGE_SERVER ingress-filtering=no interface=SERVER1
add bridge=BRIDGE_SERVER ingress-filtering=no interface=SERVER2
add bridge=BRIDGE_SERVER ingress-filtering=no interface=SERVER3
add bridge=BRIDGE_LAN ingress-filtering=no interface=LAN
add address=192.168.99.1/24 interface=BRIDGE_SERVER network=192.168.99.0
add address=192.168.98.1/24 interface=BRIDGE_LAN network=192.168.98.0
add address=192.168.1.1/24 interface=VOIP network=192.168.1.0
add address=xxx.xxx.xxx.142/29 comment="WAN_ISP1 EMPTY" interface=WAN_ISP1 network=xxx.xxx.xxx.136
add address=xxx.xxx.xxx.141/29 comment="WAN_ISP1 VOIP" interface=WAN_ISP1 network=xxx.xxx.xxx.136
add address=xxx.xxx.xxx.140/29 comment="WAN_ISP1 WEB" interface=WAN_ISP1 network=xxx.xxx.xxx.136
add address=xxx.xxx.xxx.139/29 comment="WAN_ISP1 NAS" interface=WAN_ISP1 network=xxx.xxx.xxx.136
add address=xxx.xxx.xxx.138/29 comment="WAN_ISP2 LAN" interface=WAN_ISP1 network=xxx.xxx.xxx.xxx
add address=192.168.98.0/24 comment="GW LAN" dns-server=192.168.98.1 gateway=192.168.98.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
add action=accept chain=input comment="ACCEPT ESTABILISHED,RELATED" connection-state=established,related
add action=accept chain=input comment="ALLOW PING ROUTERBOARD" protocol=icmp
add action=drop chain=forward comment="DROP INVALID PACKET" connection-state=invalid
add action=drop chain=input comment="DROP ALL OTHER ON WAN" in-interface=WAN_ISP1
add action=dst-nat chain=dstnat comment="NAT VOIP 1:1 WITH HAIRPIN NAT" disabled=yes dst-address=xxx.xxx.xxx.141 dst-port=0-65535 protocol=udp to-addresses=192.168.1.10
add action=dst-nat chain=dstnat comment="VOIP TEST TCP" dst-address=xxx.xxx.xxx.141 dst-port=40000-40999 protocol=tcp to-addresses=192.168.1.10 to-ports=40000-40999
add action=dst-nat chain=dstnat comment="VOIP TEST UDP" dst-address=xxx.xxx.xxx.141 dst-port=40000-40999 protocol=udp to-addresses=192.168.1.10 to-ports=40000-40999
add action=dst-nat chain=dstnat comment="NAT WEBSITE 1:1 WITH HAIRPIN NAT" dst-address=xxx.xxx.xxx.140 dst-port=0-65535 protocol=tcp to-addresses=192.168.99.16
add action=dst-nat chain=dstnat comment="VOIP SIM (SU LAN) TCP" dst-address=xxx.xxx.xxx.141 dst-port=45000-45999 protocol=tcp to-addresses=192.168.98.42 to-ports=45000-45999
add action=dst-nat chain=dstnat comment="VOIP SIM (SU LAN) UDP" dst-address=xxx.xxx.xxx.141 dst-port=45000-45999 protocol=udp to-addresses=192.168.98.42 to-ports=45000-45999
add action=src-nat chain=srcnat comment="NAT WEBSITE 1:1 OUT" src-address=192.168.99.0/24 to-addresses=xxx.xxx.xxx.140
add action=src-nat chain=srcnat comment="NAT VOIP 1:1 OUT" src-address=192.168.1.0/24 to-addresses=xxx.xxx.xxx.141
add action=src-nat chain=srcnat comment="NAT LAN 1:1 OUT" src-address=192.168.98.0/24 to-addresses=xxx.xxx.xxx.138
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=xxx.xxx.xxx.137 pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no target-scope=10 # route per fastweb
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
