bbahes
Enable multiple firewall rules based on find in script
Wed Jun 22, 2022 8:41 pm
I'm trying to enable/disable multiple firewall rules based on find result.
I switched from:
/ip/firewall/filter/enable numbers=6,7
to:
/ip/firewall/filter/enable numbers=[find comment="ddns_1"];
/ip/firewall/filter/enable numbers=[find comment="ddns_2"];
Is it possible to combine two lines with find part to single?
Thanks.
pe1chl
Re: Enable multiple firewall rules based on find in script  [SOLVED]
Wed Jun 22, 2022 8:57 pm
That depends on what other comments you have in your firewall rules.
When there are no other comments with ddns in them you can use: [find comment~"ddns_"]
But of course that will fail when there is also a ddns_3 or extra_ddns_2 or something like that.
bbahes
Wed Jun 22, 2022 9:20 pm
This works fine.
I have only two rules with comments ddns_1 and ddns_2. I have tested with additional ddns_3 and it also works.
Now I see that there is good reference in https://help.mikrotik.com/docs/display/ROS/Scripting which I'll check also.
Thanks for quick response.
pe1chl
Wed Jun 22, 2022 10:13 pm
Of course with "fail" I meant that "if ddns_3 exists it will enable that as well" while maybe you wanted only to enable ddns_1 and ddns_2.
So it depends on what you want if the solution works.
It is possible to make it match only ddns_1 and ddns_2 but that would make it more complicated, like "^ddns_[12]"
Users browsing this forum: aTan, dandu, Google [Bot], qatar2022 and 136 guests
