# jun/22/2022 22:55:01 by RouterOS 7.3.1
# model = RBD52G-5HacD2HnD
add admin-mac=XXXXXXXXX auto-mac=no comment=defconf name=bridge
add name=bridge1
/interface lte
set [ find ] comment=IPS2 name=lte1
set [ find default-name=ether1 ] comment=ISP1
/interface wireless
set [ find default-name=wlan1 ] country=russia4 mode=ap-bridge ssid=MikroTik
set [ find default-name=wlan2 ] band=5ghz-onlyac channel-width=20/40mhz-Ce \
country=etsi2 disabled=no frequency=5805 frequency-mode=manual-txpower \
installation=outdoor mode=ap-bridge ssid=MikroTik wmm-support=enabled
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=pool1 ranges=192.168.89.10-192.168.89.254
add address-pool=default-dhcp interface=bridge name=defconf
add address-pool=pool1 interface=bridge1 name=wifi
/routing table
add disabled=no fib name=lte
add bridge=bridge1 comment=defconf interface=wlan1
add bridge=bridge1 comment=defconf interface=wlan2
/ip settings
set allow-fast-path=no
add comment=ISP2 interface=lte1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
192.168.88.0
add address=192.168.89.1/24 interface=bridge1 network=192.168.89.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add add-default-route=no interface=lte1 use-peer-dns=no use-peer-ntp=no
192.168.88.1
add address=192.168.89.0/24 dns-server=8.8.8.8 gateway=192.168.89.1
set allow-remote-requests=yes servers=1.1.1.1 use-doh-server=\
https://1.1.1.1/dns-query verify-doh-cert=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
invalid
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=lte \
passthrough=yes src-address=192.168.89.0/24
add action=change-ttl chain=postrouting new-ttl=set:65 out-interface-list=WAN \
passthrough=yes protocol=!icmp
add action=masquerade chain=srcnat comment=ISP1 disabled=yes out-interface=\
ether1 src-address=192.168.88.0/24 to-addresses=192.168.8.177
add action=masquerade chain=srcnat disabled=yes out-interface=lte1 \
add action=masquerade chain=srcnat comment=ISP2 disabled=yes out-interface=\
lte1 src-address=192.168.89.0/24 to-addresses=192.168.9.100
add action=masquerade chain=srcnat disabled=yes out-interface=ether1 \
add check-gateway=ping comment=ISP1 disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway=192.168.8.1 pref-src=0.0.0.0 routing-table=main scope=\
30 suppress-hw-offload=no target-scope=10
add comment=ISP2_WIFI disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
192.168.9.1 pref-src=0.0.0.0 routing-table=lte scope=30 \
add disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=192.168.9.1 \
pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add comment=ISP1_WIFI disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
192.168.8.1 pref-src="" routing-table=lte scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.9.1 \
routing-table=main suppress-hw-offload=no
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
add interface=lte1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup-only-in-table disabled=no src-address=192.168.88.0/24 \
table=main
add action=lookup-only-in-table disabled=no src-address=192.168.89.0/24 \
table=lte
/system routerboard settings
set auto-upgrade=yes cpu-frequency=896MHz
/tool mac-server
/tool mac-server mac-winbox
