AThorp
LtAP mini Ether1 as LAN and LTE as WAN
Thu Jun 23, 2022 2:44 am
Hi, obviously I don't really know what I'm doing and would appreciate some help.
I have an LtAP mini with R11e LTE. I have it set up in QuickSet as LTE AP. The basic question I have is I think, how can I setup the Ether1 connection to be a LAN not a WAN port? See below for some more details.
I want to use Ether1 to connect to a local computer and have the WiFi access point available, with both on the same LAN. It is going to be a remote setup so the LTE needs to be the connection to the internet. I can't use WiFi for the local computer because it will interfere with some sensors that are attached to it.
How it is currently setup I can access the computer on Ether1 via SSH over WiFi, but it doesn't have any connection to the internet, testing by trying to ping 8.8.8.8. Although I have setup ZeroTier on the computer and can see it on the private network, which is confusing. I have connected it via WiFi and with the cable in a different setup and had an internet connection so I'm certain that it is not the computer.
Please see my config below.
# jun/23/2022 11:38:42 by RouterOS 7.3.1
# software id = THC0-RMLL
# model = RB912R-2nD
# serial number = 99150A62E503
add admin-mac=74:4D:28:##:##:## auto-mac=no comment=defconf name=bridge
/interface lte
set [ find ] allow-roaming=no band="" name=lte1
set [ find default-name=ether1 ] arp=local-proxy-arp
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country="new zealand" disabled=no distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=\
    MikroTik-13#### wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=apn1 passthrough-interface=ether1 passthrough-mac=auto
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/interface ppp-client
add apn=internet name=ppp-out1 port=usb2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add comment=defconf interface=lte1 list=WAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-server lease
add address=192.168.88.254 client-id=1:b8:27:eb:f4:7e:da mac-address=B8:27:EB:F4:7E:DA server=defconf
add address=192.168.88.253 client-id=1:b0:60:88:98:f8:b9 mac-address=B0:60:88:98:F8:B9 server=defconf
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
/system clock
set time-zone-name=Pacific/Auckland
/system gps
set port=serial0 set-system-time=yes
/tool mac-server
/tool mac-server mac-winbox
Ca6ko
Long time Member
Long time Member
Re: LtAP mini Ether1 as LAN and LTE as WAN
Thu Jun 23, 2022 9:58 am
And I'm sure it's a computer :)
It's easy to make sure of that. You need to ping 8.8.8.8 with LtAP mini.
hecatae
Fri Jun 24, 2022 3:52 pm
Weird,
In default configuration using quickset, the ether1 port is a LAN port on the LTAP Mini.
Both Ether1 and WLAN1 need to be in a Bridge, with LTE as the default WAN.
AThorp
Tue Jun 28, 2022 12:23 am
Was the computer. I wiped it and started with a new image. Not sure what was wrong.
Thnaks for your help.
Users browsing this forum: No registered users and 95 guests
