kashifzai86
Deny Rules stop Working after disabling Connection Tracking
Thu Jun 23, 2022 7:33 am
Hey to All Experts here
I m getting an issue after disabling Connection Tracking, non of my Filter Rules are working Except "Accept Rules", Please do let me know the issue, I have also attached a picture for reference.
Basically, I went through this article and did it, after it happened.
https://aacable.wordpress.com/2018/03/2 ... -mikrotik/
rextended
Re: Deny Rules stop Working after disabling Connection Tracking
Thu Jun 23, 2022 10:58 am
Simply: revert all what you change.
Another that blindly copy & paste article on Internet and call later help on forum,
instead to do the opposite (call first help on forum, and later. if is not obtained anything. search on Internet...)
For example, if you disable connection tracking, how can the firewall know if the packet is invalid or not?
Obviously the firewall is not completely functional with connection tracking off,
Every single new packet is considered a new connection because... is not tracked...
kashifzai86
Thu Jun 23, 2022 11:06 am
Yes, I understand that but why the Deny/Drop rule are not working???
rextended
Thu Jun 23, 2022 11:10 am
The answer is inside what you do not read on the text you quoted...
Extended:
How can know the firewall if the packet is coming from already estabilished connection or not,
if you disable connection tracking?...
kashifzai86
Thu Jun 23, 2022 11:30 am
Extended:
How can know the firewall if the packet is coming from an already established connection or not,
Thanks for helping me, but this article works goods, If you know any good method to separate CGNATing and distribute LOAD so I work on it
rextended
Re: Deny Rules stop Working after disabling Connection Tracking  [SOLVED]
Thu Jun 23, 2022 11:37 am
I do not criticize if article is wrong or not, I criticize the blind use of copy & paste if you do not understand rigtly what you done...
mkx
Thu Jun 23, 2022 4:06 pm
Perfect example of not understanding the article at all:
  1. article itself starts with disclaimer saying that reader should not blindly copy-paste config into own router
  2. article is about spliting unified router/firewall/pppoe server into two and instructing to disable connection tracking on the pppoe server ... but that one doesn't perform neither firewalling nor NATting, hence connection tracking is not really needed.
Sigh.
Users browsing this forum: Bing [Bot], CHUPAPEE, clambert and 220 guests
