mahfuzazam
MikroTik CCR SFP Port Issue
Thu Jun 23, 2022 12:38 pm
Hi All,
I'm having a strange SFP port issue with my CCR-1036-12G-4S router.
As soon as I reboot the router, the SFP port goes down. I manually have to disable and enable the SFP port to work again. The Auto-negotiation is disabled and the speed is set to 1G.
My SFP module details are below:
Vendor: UBNT
Model: UF-RJ45-1G
Vendor Serial: X20062802607
The same SFP module works flawlessly with my RB3011 and RB4011 routers. Is there any workaround for this? Please help.
erlinden
Re: MikroTik CCR SFP Port Issue
Thu Jun 23, 2022 12:39 pm
What RouterOS version and firmware are you using?
rextended
Thu Jun 23, 2022 12:42 pm
Have you asked for support on the Ubiquiti Forum or Ubiquiti Support?
mahfuzazam
Thu Jun 23, 2022 1:31 pm
I'm using the latest stable v6.49.6 version.
mahfuzazam
Thu Jun 23, 2022 1:32 pm
This is happening with all SFP modules. Recently tried with ATOP modules as well, but had same result.
mahfuzazam
Thu Jun 23, 2022 5:49 pm
I got it working with a simple startup script, which disables and then enables the SFP interface.
But wanted to know if this can be fixed without any scheduler. Thanks for helping
chechito
Thu Jun 23, 2022 6:28 pm
other end of that link is configured manually at 1g ?
mahfuzazam
Thu Jun 23, 2022 10:01 pm
The line came from a media converter which auto negotiates to 1G when connected to switch via ethernet cable.
Also, the same link works perfectly with SFP module, when connected to RB3011, 4011.
This is why I'm confused. Is there any settings to be done from the CCR end to have it running without scripts??
StubArea51
Trainer
Trainer
Thu Jun 23, 2022 10:18 pm
This isn't normal behavior for a CCR1036, what version of RouterOS are you running and how old is the CCR?
mahfuzazam
Fri Jun 24, 2022 7:58 am
I'm running latest stable version 6.49.6 and the router model is CCR 1036-12G-4S. The router was purchased 7-8 years ago.
StubArea51
Trainer
Trainer
Fri Jun 24, 2022 8:28 am
What is the output of
system health print
mahfuzazam
Fri Jun 24, 2022 8:30 am
system health print
[M@MikroTik] > system health print
fan-mode: auto
use-fan: main
active-fan: main
cpu-overtemp-check: yes
cpu-overtemp-threshold: 100C
cpu-overtemp-startup-delay: 1m
voltage: 24V
current: 1547mA
temperature: 30C
cpu-temperature: 56C
power-consumption: 37.1W
fan1-speed: 2704RPM
fan2-speed: 2704RPM
Users browsing this forum: adwlodaro, Bing [Bot], keshav, Maggiore81, remilucia and 186 guests
