deadkat
unknown operator "activate in environment"
Thu Jun 23, 2022 7:40 pm
A coworker of mine was poking around in the terminal and noticed that one of the available operators inside of parentheses for a `put` or `if` statement is the following `<%% activate in environment`
however it doesn't seem to be doing anything with different types of data given to it.
does anyone use this operator or know what it would be used for? I can't find anything about this in the docs.
rextended
Re: unknown operator "activate in environment"
Fri Jun 24, 2022 5:24 pm
terminal code
[test@test] > :put [:parse ":local test (0 <%% 1)"]
(eval /localname=$test;value=(<%% 0 1))
[test@test] > :put [:parse ":local test (0 < 1 % 2 % 3)"]
(eval /localname=$test;value=(< 0 (% (% 1 2) 3)))
Users browsing this forum: saied and 27 guests
