antwal
SXT 5 AC - Wireless link issues at 1,8 km
Fri Jun 24, 2022 12:57 pm
Hello everyone,
I have problems with a link between two SXT 5 AC, I have tried different configurations but the most stable one is with 802.11 in WPA2;
I also tried with NV2 and NSTREME but the link is not successful, also the maximum speed I reach is 50/50 Mbps
With firmware 7.2.3 the link is very unstable, while using version 6.48.6 it is much better.
I am attaching the configuration for firmware 6.48.6 if someone can give me useful advice to improve the link in order to have the maximum possible bandwidth.
6.48.6 - Bridge : https://pastebin.com/xqJwid0q
6.48.6 - Station Bridge : https://pastebin.com/DcD2nNP5
Bandwidth Test:
Thank you.
ivicask
Re: SXT 5 AC - Wireless link issues at 1,8 km
Fri Jun 24, 2022 1:26 pm
What is CPU load during bandwidth test? That is only single core cpu, it cant generate much traffic, use PC to do tests.
antwal
Fri Jun 24, 2022 1:45 pm
In idle, 3 -9 %, during the test 98-100%; currently i don't have a pc on the other side but i can connect it and test via iperf
mkx
Fri Jun 24, 2022 1:51 pm
... during the test 98-100% ...
That's the problem with your testing procedure. So yes, do the test using iperf through the wireless link.
According to radio stats it should be possible to push at least 150Mbps, 300Mbps is probably unreachable.
Ca6ko
Long time Member
Long time Member
Fri Jun 24, 2022 10:05 pm
You are measuring the traffic that the SXT processor can generate. You measure it in the most processor-heavy TCP mode in both directions. Measure in UDP separately receive and transmit you get the highest possible speeds. You should not run the traffic generator on the device you are testing, the results will be biased.
jace
Mon Jun 27, 2022 10:29 pm
Change the radio to 5GHz-only-AC.
NV2 is not optimal for these devices.
antwal
Thu Jun 30, 2022 4:28 pm
ok I did some tests but honestly the performances are very poor
ivicask
Thu Jun 30, 2022 4:58 pm
You are testing both ways and over TCP, for that device and 2km its very good result...
Try testing one way only, and also try test UDP traffic, its not only TCP that will go thru that link...
I got very same APs and at same distance, i get 450mbit UDP in one direction(around 170mbit both ways same time)
Also when i test TCP both ways i get 50/50mbit same as you, but one way its around 150mbit.
erlinden
Have you missed the remarks regarding your test procedure? Don't use bandwidth test, use iPerf to (only) test network speed.
rextended
Thu Jun 30, 2022 5:03 pm
Exactly
and 802.11 is not full duplex, is half duplex... when tx can not rx and vice-versa.
TCP 50+50 = 100 and for a 2km link with CCQ at 60%/70% is very good.....
antwal
Thu Jun 30, 2022 5:20 pm
okay, I'll do further tests on this, otherwise I thought I'd replace them with the "LHG XL 5 ac" but only if you can have at least 400Mbps (200 + 200)
According to the scheme, the SXTs reach 1.5 km instead the LHGs at 20km for 802.11ac "866Mbps" but I have seen that the results are much lower so I am perplexed about it
rextended
Thu Jun 30, 2022 5:27 pm
Probably there are some reason if the dynadish cost more money than that lhg model....
antwal
Thu Jun 30, 2022 5:44 pm
the price from the supplier between dynadish 5 and lhg xl 5 ac, is really minimal, only 30 euros of difference
compare all three:
DynaDish 5 - 5GHz, 25dBi, TX Power 31dBm, 1xGLAN, 802.11a / n / ac, RouterOS L3
LHG XL 5 ac - 5GHz, 27dBi, TX Power 25dBm, 1xGLAN, 802.11ac, RouterOS L3
SXT 5 ac - 5GHz, 13dBi, TX Power 31dBm, 1xGLAN, 802.11aс, RouterOS L4
For the moment I will try to make the SXT work better, then eventually I will evaluate the other two alternatives
rextended
Thu Jun 30, 2022 6:12 pm
ignoring this (jus for compare only the other two)
SXT 5 ac - 5GHz, 13dBi, TX Power 31dBm, 1xGLAN, 802.11a/n/ac, RouterOS L4
Regardless your country limits:
DynaDish 5 - 5GHz, 25dBi, TX Power 31dBm, 1xGLAN, 802.11a/n/ac, RouterOS L3
25 + 31 = 56
LHG XL 5 ac - 5GHz, 27dBi, TX Power 25dBm, 1xGLAN, 802.11a/n/ac, RouterOS L3
27 + 25 = 52
56 - 52 = 4
and very approx +3 = double tx power on logarithmic scale...
4 = more than the double
DynaDish can transmit more than double power,
LHG can receive (approx) the double better than DynaDish... But also, for this, receive better the interferencies...
But remember: do not use for compare the 6Mbit/s power,
for compare use, for example MCS9...
22 on DynaDish and 18 on LHG
ivicask
Thu Jun 30, 2022 7:19 pm
I can spare you all the trouble, getting longer range aps won't get you much benefit, you will have about same speeds at those distance, they only perform better at bigger distances..
jace
Sat Jul 02, 2022 1:25 pm
Try to check the channel noise, maybe lower or higher channel ?
regin
Wed Aug 31, 2022 10:43 pm
I have the same problem, model 922UAGS-5HPacD with mipsbe and atheros ar9888 chipset.
Already in another ptp with the model RBDiscG-5acD with arm and chipset IPQ4019 works perfectly.
I believe that the problem is there, related to the radio architecture or the chipset.
Users browsing this forum: Amaan, karhill and 88 guests
