mikhan
How to use "input accept communities" in BGP?
Fri Jun 24, 2022 5:21 pm
https://help.mikrotik.com/docs/display/ROS/BGP
input.accept-comunities (string; Default: ) A quick way to filter incoming updates with specific communities. It allows filtering incoming messages directly before they are even parsed and stored in memory, that way significantly reducing memory usage. Regular input filter chain can only reject prefixes which means that it will still eat memory and will be visible in /routing route table as "not active, filtered". Changes to be applied required session refresh.
I use a service that provides a bunch of bgp communities and I want to filter some of them.
E.g. I need 65444:700 and 65444:710
so I add:
/routing filter community-list
add communities=65444:710,65444:700 disabled=no list=some_list
I edit my bgp connection to enable input.accept-communities
/routing bgp connection
add as=*** disabled=no hold-time=4m input.accept-communities=some_list \
    .filter=bgp_in keepalive-time=1m listen=yes local.address=*** .role=\
    ebgp multihop=yes name=some_bgp output.filter-chain=discard \
    remote.address=*** .as=65444 router-id=*** \
    routing-table=main
filter to enable gw to routes:
/routing filter rule
add chain=bgp_in disabled=no rule="set gw some_gw; accept"
But nothing happens, I still receive all the communities.
It works only f I use filtering like below:
add chain=bgp_in disabled=no rule="if ( bgp-communities equal 65444:700 || bg\
    p-communities equal 65444:710) {set gw some_gw; accept}"
But it's a waste of resources...
mikhan
Re: How to use "input accept communities" in BGP?
Thu Jul 21, 2022 12:31 pm
anyone?
alexkerch
Sun Sep 25, 2022 9:30 pm
Please tell me, were you able to solve your problem and in what way?
mikhan
Tue Sep 27, 2022 1:21 pm
No. They say it's a bug in routeros.
mikhan
Thu May 25, 2023 10:25 am
anyone? :)
Institor
Sun Aug 13, 2023 11:19 am
WTF mikrotik? Nobody uses this feature?
i'd like to use .accept-comunities in BGP to reduce memory usage (according to VERY poorly written documentation mentioned above), but it's not working.
How it is supposed to work? Community list in /routing/filters or directly enter communities to input.accept-communities?
Anyway, can anyone provide a link to where
nithinkumar2000
Thu Nov 16, 2023 3:11 pm
Looking for same Answer.
Hope some one can Help
nithinkumar2000
Sun Nov 19, 2023 10:03 pm
Appriciate if any one can put some light into this topic!!!
Users browsing this forum: No registered users and 20 guests
