konclave
Routing issue on Hex with OpenVPN client set up
Sat Jun 25, 2022 1:57 am
I use Mikrotik with the WiFi AP connected as the OpenVPN client and try to route all the traffic (except the connection to Mikrotik itself) from the AP through the VPN tunnel
Mikrotik is connected to the DSL router.
Here's the configuration I use:
add admin-mac=DC:3C:6C:AA:EF:BB auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/port
set 0 name=serial0
/ppp profile
add change-tcp-mss=yes name=OVPN-client only-one=yes use-encryption=required \
    use-mpls=no
/interface ovpn-client
add certificate=client cipher=aes128 connect-to=62.63.64.65 mac-address=\
    FE:BD:BD:EE:CD:EF name=myvpn profile=OVPN-client protocol=udp user=user
/routing table
add fib name=vpn_traffic
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat out-interface=myvpn
add dst-address=0.0.0.0/0 gateway=192.168.2.1
add dst-address=0.0.0.0/0 gateway=myvpn routing-table=vpn_traffic
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/routing rule
add action=lookup-only-in-table dst-address=192.168.0.0/24 table=main
add action=lookup disabled=yes src-address=192.168.88.0/24 table=vpn_traffic
/system clock
/tool mac-server
/tool mac-server mac-winbox
Routing rule is disabled because right after I enable it, I loose the connection to the Mikrotik and the connection to the outer network as well.
add action=lookup disabled=no src-address=192.168.88.0/24 table=vpn_traffic
-> connection lost and I have to reset the device.
I don't understand what I did wrong. Could anyone please help?
tangent
Re: Routing issue on Hex with OpenVPN client set up
Sat Jun 25, 2022 8:35 am
First off, you need something like "dst-address=!192.168.88.1" in that routing rule to exclude traffic destined for the router itself.
As for the rest:
Why are you setting a MAC address on the connection?
Have you verified that your connection is established, e.g. by "/tool ping src-address=10.8.0.10 8.8.8.8" or "…interface=myvpn" to force the ping packets out the OpenVPN interface?
OpenVPN over UDP has been plagued with bugs and incompatibilities. Are you on the latest RouterOS? (I wouldn't have to ask if you'd left the block comment at the top of the /export output in place…)
konclave
Tue Jun 28, 2022 12:12 am
I'm using the latest stable RouterOS 7.3.1. And it's not allowed to create a routing rule with inversion there =(
I didn't set the MAC address, it was set by default. And in the GUI in web admin that field is required – something, at least 00:00:00:00:00 should be entered there.
Yes, when I run "/tool ping src-address=10.8.0.10 8.8.8.8", it successfully pings the destination server.
Unfortunately, I couldn't manage the server settings, so, I'm using it as is.
tangent
Tue Jun 28, 2022 3:18 am
On deeper examination, both problems are solved with:
/routing rule
add action=lookup-only-in-table dst-address=192.168.88.0/24 table=main
You had the wrong third octet in the IP address.
Now it says "if it's destined for a local address, skip the VPN; otherwise, use it."
If you really did mean 192.168.0.0, then either you need a wider mask (e.g. /16, arguably an abuse of RFC 1918) or you've got additional subnets not showing up in your posted information, so no wonder we're confused. 😉
Have you verified that your connection is established…
Okay, then, move on to "/tool/traceroute" to ensure it takes the path you expect.
There are a plethora of VPN providers, and RouterOS offers several VPN technologies, including two new ones in v7. I refuse to believe you have just one option.
konclave
Tue Jun 28, 2022 11:52 pm
/routing rule
Thanks so much! That solved the loosing access issue. I typed 192.168.0.0 instead of 192.168.88.0 and didn't notice it.
Traceroute says that the traffic goes not through the VPN, but via the bridge interface and DSL router:
The first address in the list is 192.168.2.1 which is the address of DSL router.
But it's when I run traceroute on Mikrotik.
If I run traceroute on my laptop, that is connected to Mikrotik over AP WiFi and has IP 192.168.88.199, then the first and the only item in the list is 192.168.88.1 – the Mikrotik bridge interface.
By the way, If I connect to the VPN server from my laptop directly, everything works fine.
It's not some random VPN provider, so I just need the access to that specific server and it offers only this type of connection. So, I have to deal with it. 🙁
konclave
Wed Jun 29, 2022 7:53 am
Just to clearify:
I do traceroute with the same params as ping: src-address=10.8.0.10 (the address of the ovpn-client interface). And when I set the src-address as 192.168.88.197, then traceroute resposes that it gets timeout for each request.
Does that mean that it sends requests through the VPN and just doesn't get any response and VPN connection doesn't work no matter that it shows "connected" in the interface status?
Maybe I didn't set up OpenVPN interface correctly?
Here's the part of the config without certificates and user/password:
remote 62.63.64.65 1194
float
nobind
proto udp
dev tun
sndbuf 0
rcvbuf 0
keepalive 15 60
comp-lzo adaptive
auth-user-pass
client
auth SHA1
cipher AES-128-CBC
ns-cert-type server
konclave
Wed Jun 29, 2022 11:47 am
Looks like the issue is in the OpenVPN connection params. According to Wiki, RouterOS doesn't support UDP mode (but what does
protocol=udp
then mean?) and LZO compression (
comp-lzo adaptive
in opvn config). So,I guess, it's quite impossible to set up the OpenVPN client on Mikrotik, right?
konclave
Wed Jun 29, 2022 11:58 am
Okay, looks like Wiki is outdated, because I found that UDP is now supported in RouterOS 7.
tangent
Wed Jun 29, 2022 12:36 pm
Wiki is outdated
To a first approximation, the new docs are for v7, while the old wiki is for the legacy v6 line and earlier.
Because not everything has been moved over to the new docs, you're still best advised to check the wiki before declaring a feature nonexistent, but in a conflict between the two, that's the basic reason for it.
Yes, and it's buggy and incomplete, as I said in my first reply.
I'm not telling you it cannot possibly work. I'm just telling you that I'm not surprised you're running into problems with it. There may be some narrow "happy path" through the problems that will work. I cannot advise, since I avoid this tarpit entirely.
konclave
Wed Jun 29, 2022 11:32 pm
Okay, looks like it's not a routing, but the OpenVPN – Mikrotik connection issue. Anyway, thank you so much for help. At list I stopped losing connection to Mikrotik after the routing rule enable. =)
Users browsing this forum: hatred, ywlhlp and 34 guests
