abhsek
IPV6 on PPPoE Client
Sat Jun 25, 2022 4:58 pm
Hello Mikrotik Community !!
My Mikrotik connects to the internet via PPPoE Client on ether 1,
now my ISP is offering IPV6, how can I use IPV6 on PPPoE?
please help me with the configuration. Thank you.
mkx
Re: IPV6 on PPPoE Client
Sat Jun 25, 2022 5:25 pm
In case of one of my ISPs it's enough to run DHCPv6 client on pppoe-out1 interface. It should be set to request prefix (address is not needed) and it should add default IPv6 route.
Then you assign IPv6 address to LAN interface (using construct like address=::1 from-pool=ipv6-pool. That should allow devices members of LAN to receive information needed to construct SLAAC addresses and start using IPv6.
abhsek
Sat Jun 25, 2022 7:41 pm
i have added that, but it somehow does not work.
i have a hotspot network and i want ipv6 to be available on that network. where am I wrong?
mkx
Sat Jun 25, 2022 10:57 pm
I'd first verify that router itself has IPv6 connectivity ... by assigning IPv6 address to a wired LAN interface.
I can't comment on hotspot, I've no experience on that. Hopefully somebody else chimes in. But the address on the hotspot interface loojs suspicious to me with the double colon at the end. I'd try to get something other than zero in the least significant 4 digits.
Sob
Sat Jun 25, 2022 11:07 pm
It's also suspicious that the manually added address uses completely different subnet, not related to prefix from DHCPv6.
romihg
Sun Jun 26, 2022 2:01 am
Something like this should work.
abhsek
Fri Sep 16, 2022 6:18 pm
Thank you all, it is working now Fine.
Users browsing this forum: GoogleOther [Bot], tangent, tryrtryrtryrt and 116 guests
