Sahafi2001
Long-term v7?
Sun Jun 26, 2022 1:39 pm
Why there is not a long-term on v7?
if i upgraded my router from 6.48.6 long term to 7.3.1, Is there any problem that effect user-manger and hotspot
mkx
Re: Long-term v7?
Sun Jun 26, 2022 1:42 pm
True long-term v7 will come as 7.12.x or something. Before that there will simply be too much development to truly stabilize something with decent working feature set.
Ca6ko
Long time Member
Long time Member
Re: Long-term v7?
Sun Jun 26, 2022 10:56 pm
version 7.1.5 is now considered, but it is not yet what it was in V6
Jotne
Re: Long-term v7?
Sun Jun 26, 2022 11:45 pm
It will be ready when its ready.
What you can do is to test the 7.3.1 on a equal router as you have and see if all function works as expected, then you can do the upgrade.
If there are noe reason (new function you need or error that can not be solved with upgrade), you do not need to upgrade.
yacsap
Re: Long-term v7?
Thu Jul 21, 2022 1:49 am
Well, v7.4 just came out with a bunch of bug fixes.
normis
Re: Long-term v7?
Fri Jul 22, 2022 10:56 am
Users browsing this forum: Amazon [Bot], DNAT, GoogleOther [Bot] and 216 guests
