byjosertag
Can’t connect Gateway Mikrotik to The Things Stack running on Localhost
Sun Jun 26, 2022 10:00 pm
Hello, I set up on a virtual machine running Ubuntu 20.0.4 The Things Stack following the guide that provides the network and everything was fine.
Now I’m adding my gateway, which is a Mikrotik WAP LR8 kit, I configure it using Winbox.
The domain where i have hosted The things stack is on my IP from virtual machine and I’m able to access it from every device in my network.
Here is the winbox configuration
where TTN-PR is the address of my private server with The things stack.
I must specify that gateway and also a Lorawan device is working fine in public The Things Stack without any problem, the problem is when I use it in localhost.
And here is the gateway added on my localhost The things stack service, where you can see that it appears as disconnected.
Actually I think that the problem is in the Mikrotik configuration, I’ve also tried chirpstack in localhost and it doesn’t found my gateway neither.
I’m stuck here and I don’t know how to fix it
I would be glad to be helped as soon as possible.
Thanks!
Users browsing this forum: miker3000 and 104 guests
