honzam
link with CubePRO = MCS1 and packetloss
Mon Jun 27, 2022 11:58 am
Description:
Short link built on 2x CubePRO. Distance 235 meters, free line of sight. RouterOS 7.3.1 on both sides
Problem:
After some time (hours), the MCS drops from 10 to 1 and start packetloss. The MCS will remain at 1. It will mostly not return to the original MCS
What was tested:
Other ROS versions: 7.2.3 and 7.3.1
various channels: 58320, 64800, 66960 Mhz
None of this helps, the MCS mostly will not return to original value until the w60G interface is turned off / on.
Ticket: SUP-85269
honzam
Re: CubePRO with trafic = MCS1 and packetloss
Mon Jun 27, 2022 12:01 pm
screen
Bruzxce
Mon Jun 27, 2022 5:14 pm
I have face this issue also in my new purchase CubePro kit. So my solution is downgrade to ROS 6 on the latest Stable FW and all are working fine. distance is almost 200+ meter with LOS
honzam
Tue Jun 28, 2022 12:06 am
With 6.49.6 ?
Does it hold even under load? Have you tried a permanent BW test?
honzam
Wed Jun 29, 2022 7:31 pm
Downgrade do latest ROS6 (6.49.6) did not help. After some time is MCS1 on link. Disable/enable 60G radio a MCS is 9
This problem is on 3 links on different locations. Always CubePRO - CubePRO
honzam
Re: link with CubePRO = MCS1 and packetloss
Fri Jul 01, 2022 10:51 am
Confirmed to be a RouterOS bug in CubePRO. After changing to CubeG (same channel and location) MCS8 holds it steady
Bruzxce
Sat Jul 09, 2022 2:55 pm
I just installed new pair of Cube Pro in one my location which cable is not an option to lay down so we install new pair of 60ay and we did not experience MCS dropping.
Users browsing this forum: Google [Bot], McSee and 80 guests
