benoitc
how to route public IP to another machine without NAT
Mon Jun 27, 2022 1:07 pm
My ISP provided me a /28 that I announce using BGP on a CCR2004. I would like to have one machine behind it using one of the IPS in this /29 as its public address but don't want to have NAT on the core router (CCR2004). The machine below will act as the router for a LAN and do NAT itself.
I am not sure how to this exactly. Since having a /31 is not possible on routeros what should I do?
tdw
Re: how to route public IP to another machine without NAT
Mon Jun 27, 2022 1:25 pm
Mikrotiks and various other devices support /32, you can use any local address on the Mikrotik for the CCR end and one of your spare public addresses for the machine end. If the public addresses are attached to a layer 2 network you will have to enable proxy ARP.
benoitc
Mon Jun 27, 2022 3:57 pm
so if assign to sfp12 10.101.1.1/32 i can use on the other machine XX.XX.XX.XX as public ip on the other machine? What about the routes? Can you share a rough example?
tdw
Re: how to route public IP to another machine without NAT  [SOLVED]
Mon Jun 27, 2022 4:37 pm
So on your CCR
add address=10.101.1.1/32 interface=sfp12 network=RR.SS.TT.UU
which will automatically add the /32 route
And if the other device were a Mikrotik
add address=RR.SS.TT.UU/32 interface=ether1 network=10.101.1.1
add comment="default gateway" distance=1 gateway=10.101.1.1
Many years ago you had to use tricks on linux, I don't believe that is any longer the case.
benoitc
Mon Jun 27, 2022 10:17 pm
So on your CCR
thanks it worked perfectly!
Users browsing this forum: Bing [Bot] and 13 guests
