AZak
Script to Enable Mangle Rule When route is unreachable
Mon Jun 27, 2022 1:15 pm
Dear All,
I kindly need help in configuring a script that enables an Mangle rule when static default route is unreachable,
Thanks in advance!
sindy
Re: Script to Enable Mangle Rule When route is unreachable
Tue Jun 28, 2022 7:57 am
While such a script is quite an easy one, there is no way to trigger it by the change of the default route availability - you have to use some kind of scheduling or other triggering mechanism (/tool netwatch). But the script you ask for is just a method to reach some actual goal; can you describe that actual goal? Maybe it could be reached without the script?
AZak
Thu Jun 30, 2022 10:18 pm
I have 2 ISPs, one with public IP and the other is DHCP. Sometimes the ISP with Public IP face some issues, so I want to remove the route mark on the DHCP Internet and enable a mangle rule on a private IP to be able to access remotely using anydesk or any other remote desktop application
sindy
Thu Jun 30, 2022 10:39 pm
For that, it should be sufficient to use the automatic failover based on recursive next-hop search. With this in place, Anydesk/TeamViewer/whatever software will re-establish the connection to the cloud once the primary WAN fails, and it will also re-establish the connection via the primary WAN again once it recovers (unless it uses UDP, as that would require additional measures).
anav
Thu Jun 30, 2022 11:20 pm
Or if that thread makes you feel sick........
Read sub para I. here ---> viewtopic.php?t=182373
Users browsing this forum: GoogleOther [Bot] and 180 guests
