epistrophy42
UPnP music stops early and skips to next track after ~3 minutes
Tue Jun 28, 2022 9:55 am
Since my RouterOS upgrade from 7.0.5 to 7.3.1 on my RB5009, my music players can't play an audio track in it's full length.
When a track is longer then 3 minutes, the track ends early and skips to the next track. This happens every ~3 minutes.
I'm using MoOde Audio music players on RaspberryPi's as Digital Media Renderers (DMRs), A Synology 1515+ NAS as a Digital Media Server (DMS) and BubbleDS as a Digital Media Controller (DMC) on Andorid phones and tablets. I only play my local music files (flac's) form the NAS.
I never had this when using RouterOS 7.0.5.
Any idea what might be the problem?
I'm considering a downgrade to 7.0.5, but I can't find the package on the Mikrotik downloads page.
I found somthing on a German Mikrotik site: routeros-7.0beta5-arm.npk. Is this the correct package for downgrading to 7.0.5?
Best regards, Mike
rextended
Re: UPnP music stops early and skips to next track after ~3 minutes
Tue Jun 28, 2022 12:09 pm
7.0beta5 is 7.0beta5, not 7.0.5
epistrophy42
Tue Jun 28, 2022 12:48 pm
So where can I download 7.0.5? I can't find it on the Mikrotik website.
epistrophy42
Tue Jun 28, 2022 12:57 pm
Furthermore:
- My network is wired all the way (1Gbps)
- The problem is not there just after a refresh/clean install of the router. It starts ~12 hours later
tangent
Tue Jun 28, 2022 2:22 pm
Do you have an IGMP querier enabled on this net? If so, what’s the timeout?
epistrophy42
Tue Jun 28, 2022 6:27 pm
No, I don't. I see nothing under Routing -> IGMP Proxy -> Interface and also nothing under Routing -> IGMP Proxy -> MFC.
tangent
Tue Jun 28, 2022 6:43 pm
I'm not talking about the IGMP Proxy feature, just the IGMP querier that complements IGMP snooping. They're related, but separate.
It's part of the bridge configuration. In WinBox, it's under Bridge → IGMP Snooping → Multicast Querier. In the CLI, "/interface bridge print" will give the info I'm after.
epistrophy42
Wed Jun 29, 2022 10:05 am
This is wat I get:
[beheerder@MikroTik] > /interface bridge print
 0 R name="filiaal-bridge" mtu=auto actual-mtu=1500 l2mtu=1514 arp=enabled arp-timeout=auto mac-address=DC:2C:6E:45:DC:08 protocol-mode=rstp fast-forward=yes
     igmp-snooping=no auto-mac=yes ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s transmit-hold-count=6 vlan-filtering=no dhcp-snooping=no
Also, the problem is most severe in the morning. During the day, the skips disappear and during the evening they are gone. My server (DMS) is restarted every night.
tangent
Wed Jun 29, 2022 10:19 am
So no querier, either. Ah, well, it was an idea.
I must say, I was mislead by your post headline and the bolded text in your first message claiming it happens "every ~3 minutes". That's precisely what an IGMP querier does: cuts off data streams at fixed time limits, when no one steps up to claim they're still wanted.
Now you say the cutoff time varies. How can you expect people to give useful answers when you don't describe the symptom properly? Post #8 isn't the time to be revealing this detail.
Since the problem is correlated with the restart period, what happens if you leave this DMS thingy running overnight? Does the good performance from the night before then continue into the next morning?
erlinden
Wed Jun 29, 2022 11:06 am
Any reason you have Protocol Mode set to RSTP? Otherwise you might want to give none a try.
epistrophy42
Wed Jun 29, 2022 5:46 pm
As far as I know, the bridge was created that way with protocol RSTP. I was not aware of this setting before printing the bridge settings.
I'm still in the process of finding patterns in this odd behavior. Today in Wireshark, I saw some suspicious packets from 2 devices (a Solar Power Inverter and a Thermostat) around the skips.
At the end of this week, I will further investigate the traffic on my LAN with Wireshark with precise timings of the skips. Then I will get back to you with some results.
Thanks so far...
epistrophy42
Thu Jun 30, 2022 5:40 pm
Yesterday, I downgraded my RB5009 from 7.3.1 to 7.1.0. So far I had not one skipping problem. :D
Tried on 2 different streamers: both working perfectly again.
For 7.1.0, I restored the same configuration as used for 7.3.1.
So what causes the skips on 7.3.1?
tangent
Thu Jun 30, 2022 5:53 pm
7.1.0 to 7.3.1 spans 6 months of releases.
Can you at least do us the favor of bisecting among the stable releases between? That will give us a single ChangeLog to scan, which may provide an answer.
By the way, I take it that turning off RSTP didn't help? I didn't expect that it would.
Znevna
Thu Jun 30, 2022 7:56 pm
Try with
/interface/ethernet/switch/set [find] cpu-flow-control=no
I remember they "fixed" something on the switch between those releases.
Not sure if it helps with your case, but it does in others.
epistrophy42
Fri Jul 01, 2022 2:14 pm
Hello Znevna,
No luck: i get this message:
[beheerder@MikroTik] > /interface/ethernet/switch/set [find] cpu-flow-control=no
failure: cpu flow control not supported
By the way: the problem is back using routerOS 7.1.0 :(
It started skipping again 24 hours after my downgrade to 7.1.0.
When I startup 2 streamers with tracks longer then 3 minutes, I see these pattern:
  • Tracks skips to the next track after 3 minutes of playing
  • When streamer 1 is started on 12:00, it skips on ~12:03, ~12:06, ~12:09 etc.
  • When streamer 2 is started on 12:01, it skips on ~12:04, ~12:07, ~12:10 etc.
Maybe this means that the skipping is invoked on the streamers itself.
rextended
Fri Jul 01, 2022 2:28 pm
This is the older ufficially available:
https://download.mikrotik.com/routeros/ ... .9-arm.npk
Try to bypass RB5009 with one switch for link the devices, if the problem persist, probably they have not any to do with RB...
Also seeing only the "bridge" print, instead of a full export, and a diagram how the devices are connected, is indicative of nothing...
And to say "before it didn't do this with the xxx version", I wonder why you updated it if it worked, and how do you make sure it's the only updated software (and hardware) in the rest of the network...
epistrophy42
Fri Jul 01, 2022 3:47 pm
I enabled debug logging on the Moode Audio Streamers: here you see some logging that is repeated every ~3 minutes:
20220701 143556 engine-mpd: Idle timeout event=(changed: player)
20220701 143556 engine-mpd: Get new status
20220701 143556 engine-mpd: Generating enhanced metadata
20220701 143559 enhanceMetadata(): coverurl: (http://192.168.0.3:50002/transcoder/jpegtnscaler.cgi/ebdart_orig/2719788.jpg)
20220701 143559 enhanceMetadata(): UPnP url
20220701 143559 engine-mpd: Metadata returned to client: Size=(34)
20220701 143559 engine-mpd: Get initial status
20220701 143559 engine-mpd: UI state=(play), MPD state=(play)
20220701 143559 engine-mpd: Wait for idle timeout
20220701 143911 engine-mpd: Idle timeout event=(changed: player)
20220701 143911 engine-mpd: Get new status
20220701 143911 engine-mpd: Generating enhanced metadata
20220701 143914 enhanceMetadata(): coverurl: (http://192.168.0.3:50002/transcoder/jpegtnscaler.cgi/ebdart_orig/2719782.jpg)
20220701 143914 enhanceMetadata(): UPnP url
20220701 143914 engine-mpd: Metadata returned to client: Size=(34)
20220701 143914 engine-mpd: Get initial status
20220701 143914 engine-mpd: UI state=(play), MPD state=(play)
20220701 143914 engine-mpd: Wait for idle timeout
epistrophy42
Fri Jul 01, 2022 4:00 pm
@rextended
Why update when it worked? That's obvious (and you know that): new versions ideally should work better :-) I'm a developer and I know that's not always the case.
I switched to another ISP (KPN Fiber 1Gbps Up/Down) and upgraded RouterOS. Then this problem started.
First I thought it was the ISP, so I switched back to my old ISP (Ziggo, COAX) but the problem remained.
Then I think it's obvious that the upgrade might caused the problem, because that's the only change left.
I will try my old TP-link router and see if the problems remains.
epistrophy42
Fri Jul 01, 2022 4:09 pm
Here my routerOS config. My IP-address is replaced by my.ip.xxx.xxx.
# jul/01/2022 14:05:38 by RouterOS 7.1
# software id = LK6U-MMYI
# model = RB5009UG+S+
# serial number = <CENSORED>
add name=filiaal-bridge
add comment=filiaal-conf name=filiaal-interface-list-wan
add comment=filiaal-conf name=filiaal-interface-list-lan
add comment=filiaal-conf name=filiaal-pool ranges=192.168.0.100-192.168.0.200
add address-pool=filiaal-pool interface=filiaal-bridge name=\
    filiaal-dhcp-server
add bridge=filiaal-bridge interface=ether2
add bridge=filiaal-bridge interface=ether3
add bridge=filiaal-bridge interface=ether4
add bridge=filiaal-bridge interface=ether5
add bridge=filiaal-bridge interface=ether6
add bridge=filiaal-bridge interface=ether7
add bridge=filiaal-bridge interface=ether8
add comment=filiaal-conf interface=ether1 list=filiaal-interface-list-wan
add comment=filiaal-conf interface=filiaal-bridge list=\
add address=192.168.0.1/24 interface=filiaal-bridge network=192.168.0.0
/ip dhcp-client
add interface=ether1 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.0.2 comment=ap-c3200 mac-address=84:16:F9:CB:B4:24 \
    server=filiaal-dhcp-server
add address=192.168.0.3 comment=synology-1515 mac-address=00:11:32:39:A6:18 \
add address=192.168.0.4 comment=asrock mac-address=D0:50:99:A6:B6:C4 server=\
    filiaal-dhcp-server
add address=192.168.0.5 comment=video-server mac-address=E4:5F:01:41:7F:3A \
add address=192.168.0.6 comment=filiaal-t14 mac-address=8C:8C:AA:A2:41:4F \
add address=192.168.0.7 comment=filiaal-t14-wifi mac-address=\
    18:65:71:F4:2C:AC server=filiaal-dhcp-server
add address=192.168.0.8 comment=filiaal-t27hv mac-address=B4:0E:DE:53:50:6B \
add address=192.168.0.9 comment=kinetiek-t14 mac-address=8C:8C:AA:EA:FF:BB \
add address=192.168.0.10 comment=kinetiek-t14-wifi mac-address=\
    E0:2B:E9:BB:FB:6B server=filiaal-dhcp-server
add address=192.168.0.11 comment=kinetiek-t27hv mac-address=18:65:71:F4:2C:2A \
add address=192.168.0.12 comment=galaxy-tab-s5e mac-address=A2:95:6A:B4:DF:8E \
add address=192.168.0.13 comment=galaxy-tab-s2 mac-address=E0:AA:96:74:C3:BA \
add address=192.168.0.14 comment=galaxy-tab-a10 mac-address=D4:E6:B7:3E:C0:59 \
add address=192.168.0.15 comment=galaxy-a52s mac-address=8E:78:06:6C:0A:E5 \
add address=192.168.0.16 comment=galaxy-a5 mac-address=1C:23:2C:36:F6:27 \
add address=192.168.0.17 comment=iphone-mike mac-address=58:1F:AA:31:FC:64 \
add address=192.168.0.20 comment=raspi-huiskamer mac-address=\
    B8:27:EB:FA:0A:0A server=filiaal-dhcp-server
add address=192.168.0.21 comment=raspi-kinetiek-wire mac-address=\
    B8:27:EB:7E:F1:5A server=filiaal-dhcp-server
add address=192.168.0.22 comment=raspi-filiaal-wire mac-address=\
    B8:27:EB:65:92:ED server=filiaal-dhcp-server
add address=192.168.0.23 comment=raspi-slaap-wire mac-address=\
    B8:27:EB:AE:10:2C server=filiaal-dhcp-server
add address=192.168.0.24 comment=raspi-zolder-wire mac-address=\
    B8:27:EB:1F:7F:A7 server=filiaal-dhcp-server
add address=192.168.0.25 comment=raspi-keuken-wire mac-address=\
    B8:27:EB:E3:5A:00 server=filiaal-dhcp-server
add address=192.168.0.26 comment=raspi-p1-mon mac-address=B8:27:EB:00:E4:A9 \
add address=192.168.0.30 comment=odroid-n2+ mac-address=00:1E:06:42:75:C1 \
add address=192.168.0.40 comment=netgear-gs116ev2 mac-address=\
    3C:37:86:1B:42:3A server=filiaal-dhcp-server
add address=192.168.0.50 comment=sunny-boy mac-address=00:40:AD:AE:11:2C \
add address=192.168.0.51 comment=thermo-smart mac-address=00:1E:C0:3F:A5:FB \
add address=192.168.0.60 comment=hp-x476dw mac-address=58:20:B1:DF:58:18 \
add address=192.168.0.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.0.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
    established,related,untracked
    invalid
    in-interface-list=!filiaal-interface-list-lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    connection-state=new in-interface-list=filiaal-interface-list-wan
    "filiaal-conf: block DNS UDP-requests from WAN" connection-state=new \
    dst-port=53 in-interface-list=filiaal-interface-list-lan protocol=udp
    "filiaal-conf: block DNS TCP-requests from WAN" connection-state=new \
    dst-port=53 in-interface-list=filiaal-interface-list-lan protocol=tcp
add action=masquerade chain=srcnat comment="filiaal-conf: LAN-2-WAN" \
    ipsec-policy=out,none out-interface-list=filiaal-interface-list-wan
add action=masquerade chain=srcnat comment=\
    "filiaal-conf: hairpin for LAN-clients to LAN-servcies" dst-address=\
    192.168.0.3 out-interface-list=filiaal-interface-list-lan protocol=tcp \
    src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment=syno-ftp dst-address=my.ip.xxx.xxx \
    dst-port=21 protocol=tcp to-addresses=192.168.0.3 to-ports=21
add action=dst-nat chain=dstnat comment=syno-smtp dst-address=my.ip.xxx.xxx \
    dst-port=25 protocol=tcp to-addresses=192.168.0.3 to-ports=25
add action=dst-nat chain=dstnat comment=syno-http dst-address=my.ip.xxx.xxx \
    dst-port=80 protocol=tcp to-addresses=192.168.0.3 to-ports=80
add action=dst-nat chain=dstnat comment=syno-http-ssl dst-address=\
    my.ip.xxx.xxx dst-port=443 protocol=tcp to-addresses=192.168.0.3 to-ports=\
    443
add action=dst-nat chain=dstnat comment=syno-smtp-tls dst-address=\
    my.ip.xxx.xxx dst-port=587 protocol=tcp to-addresses=192.168.0.3 to-ports=\
    587
add action=dst-nat chain=dstnat comment=syno-imap-ssl dst-address=\
    my.ip.xxx.xxx dst-port=993 protocol=tcp to-addresses=192.168.0.3 to-ports=\
    993
add action=dst-nat chain=dstnat comment=syno-bitwarden dst-address=\
    my.ip.xxx.xxx dst-port=2021 protocol=tcp to-addresses=192.168.0.3 \
    to-ports=2021
add action=dst-nat chain=dstnat comment=syno-audio-ssl dst-address=\
    my.ip.xxx.xxx dst-port=6001 protocol=tcp to-addresses=192.168.0.3 \
    to-ports=6001
add action=dst-nat chain=dstnat comment=syno-file-ssl dst-address=\
    my.ip.xxx.xxx dst-port=7001 protocol=tcp to-addresses=192.168.0.3 \
    to-ports=7001
add action=dst-nat chain=dstnat comment=syno-dwnld-ssl dst-address=\
    my.ip.xxx.xxx dst-port=8001 protocol=tcp to-addresses=192.168.0.3 \
    to-ports=8001
add action=dst-nat chain=dstnat comment=syno-torrent dst-address=my.ip.xxx.xxx \
    dst-port=16881 protocol=tcp to-addresses=192.168.0.3 to-ports=16881
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Amsterdam
/system ntp client
set enabled=yes
/system ntp client servers
add address=1.nl.pool.ntp.org
add address=2.nl.pool.ntp.org
add address=2.europe.pool.ntp.org
add address=3.europe.pool.ntp.org
/system routerboard settings
set cpu-frequency=auto
rextended
Fri Jul 01, 2022 4:47 pm
ok...
I just start to read and instantly notice this:
the bridge has no admin mac, and no "none" as protocol mode, as already wroten from @erlinden
the DHCP server have the default lease time: 10 min, try to increase that to 1 hour
missing netmask=24
this two??? you block your device to use the routerboard dns... despite the comment, block the LAN request, not the WAN...
and you specify /ip dhcp-server network ... dns-server=192.168.0.1
these two rules are perfectly useless (also if uselessly block already blocked incoming from WAN) and block your devices
epistrophy42
Re: UPnP music stops early and skips to next track after ~3 minutes  [SOLVED]
Fri Jul 01, 2022 5:18 pm
@rextended: Increasing the lease time of the DHCP-server from 10 minutes to 1 hour has directly a positive effect!
I'm testing 4 MoOde streamers simultaneously and they all play beyond the 3 minutes mark. :-)
You're right: I should block the WAN for DNS-requests.
epistrophy42
Fri Jul 01, 2022 5:34 pm
Then this are the fixes in the config:
# increase lease-time from default 10 min to 1 hour
add address-pool=filiaal-pool interface=filiaal-bridge lease-time=1h name=filiaal-dhcp-server
# add a netmask 24 (255.255.255.0)
add address=192.168.0.0/24 dns-server=192.168.0.1,8.8.8.8 gateway=192.168.0.1 netmask=24
# block the WAN, not the LAN
    dst-port=53 in-interface-list=filiaal-interface-list-wan protocol=udp
    dst-port=53 in-interface-list=filiaal-interface-list-wan protocol=tcp
Thank you so much!
tangent
Fri Jul 01, 2022 5:35 pm
If that DHCP change helps as you say, it can only be because it stretches the incidence of the core problem by 6x. It'll still happen, just more rarely.
Step 1: Increase it to a day, so that hopefully it happens while you're asleep.
Step 2: Yell at the moOde developers and get them to understand that renewing a DHCP address should never cause the service to stall. The IP never changes, so all it's doing is updating a database record on the server side saying, "Yes, I still want this IP."
I'm not supporting 10-minute lease times. That kinda sucks, IMHO, but I also don't see why it should cause any user-visible effect. At worst, it should be a bit wasteful, is all. The only time you should need renewal times that short is when you've badly over-provisioned your DHCP space and need high churn to keep slots free for new devices, replacing ones that have gone MIA. In a home environment, you should be able to afford abandoned DHCP server slots that go months between reuses.
rextended
Fri Jul 01, 2022 5:40 pm
You MUST delete that useless rules, you have previous drop all on input that not coming fro LAN that already do same job for all services, not only DNS.
You can paste this on terminal, for "final fix"
/int bri
set filiaal-bridge auto-mac=no admin-mac=[/int eth get ether2 orig-mac-address] protocol-mode=none
it add also stability when one device reboot or connect/disconnect to ethernet port (avoid the bridge table recalc for RSTP which inhibits the bridge for 1-2 sec)
epistrophy42
Fri Jul 01, 2022 7:29 pm
@rextended and @tanget: Thank you so much for your help. Very much appreciated!
epistrophy42
Mon Jul 25, 2022 2:43 pm
Last week, the skip to next track problem was back. After I replaced the old TP-link router, the problem persisted. So apparently it was not due to the RouterOS and/or Mikrotik RB5009.
After a long search, I determined that the problem was caused on my Synology NAS. In the log files I saw that the Synology had a VPN-disconnection/connection cycle every 3 minutes.
After each VPN disconnect, the song jumped to the next song about 10 seconds after the disconnection. That has to do with the buffer that Moode uses (i.e. the buffer contains ~10 seconds of music). Moode then gives this error: MPD error CURL failed: transfer closed with bytes remaining to read.
The problem was caused by an error in the ovpn file of Proton VPN. With a small adjustment of the ovpn file, I get a stable VPN connection without dropouts and the skipping problem is finally solved. :D
Users browsing this forum: adwlodaro, djvabe, GoogleOther [Bot], loloski and 139 guests
