DeepB
CRS354 VLANs 100% cpu load
Tue Jun 28, 2022 3:47 pm
I have multiple CRS354 switches. I added VLANs in RouterOS. Now the switch has 100%cpu load and a high package loss.
I believe I used this to set up the VLANs: https://help.mikrotik.com/docs/display/ ... NFiltering
I used (my comment after ##)
set bridge=bridge1 interface=ether1 pvid=20 frame-types=admit-only-untagged-and-priority-tagged number=0 ##for all ports that are assigned a fixed vlan.
set bridge=bridge1 interface=ether2 pvid=20 frame-types=admit-only-untagged-and-priority-tagged number=1
/interface bridge vlan
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48 vlan-ids=12 ## for all the vlans and the ports I want to have tagged traffic over.
/interface vlan
add interface=bridge1 vlan-id=1 name=default
add interface=bridge1 vlan-id=12 name=WIFI-public
I then activated "VLAN Filtering" in Bridge in WinBox.
I have only one bridge, it is called bridge1.
Is this the wrong approach? It seems RouterOS uses the CPU for routing instead of the routing-chip?
Daniel
biomesh
Long time Member
Long time Member
Re: CRS354 VLANs 100% cpu load
Tue Jun 28, 2022 3:57 pm
Did you enable l3hw offloading? This is primarily a switch and while there are some layer 3 routing features offloaded to the switch chip, the CPU is not going to be able to handle much routing outside of the functionality in the l3hw offloading specs.
https://help.mikrotik.com/docs/display/ ... Offloading
You should also post your full config so others can see if there are any other issues present.
DeepB
Tue Jun 28, 2022 4:11 pm
my config:
export hide-sensitive
# jan/02/1970 19:45:50 by RouterOS 7.3.1
# software id = 7GPA-Q0WH
# model = CRS354-48G-4S+2Q+
# serial number = XXXXXXX
add admin-mac=DC:2C:6E:B3:AB:FB auto-mac=no comment=defconf ingress-filtering=no name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=OFFLINE vlan-id=99
add interface=bridge1 name=PV vlan-id=90
add interface=bridge1 name=VOIP vlan-id=20
add interface=bridge1 name=WIFI-internal vlan-id=13
add interface=bridge1 name=WIFI-mixed vlan-id=14
add interface=bridge1 name=WIFI-public vlan-id=12
add interface=bridge1 name=default vlan-id=1
add interface=bridge1 name=management vlan-id=100
add name=WAN
add name=LAN
/interface lte apn
/port
set 0 name=serial0
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether1
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether6
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether7
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether8
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether9
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether10
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether11
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether12
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether13
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether14
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether15
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether16
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether17
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether18
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether19
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether20
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether21
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether22
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether23
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether24
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether25
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether26
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether27
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether28
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether29
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether30
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether31
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether32
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether33
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether34
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether35
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether36
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether37
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether38
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether39
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether40
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether41
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether42
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether43
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether44
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether45
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether46
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether47
add bridge=bridge1 comment=defconf ingress-filtering=no interface=ether48
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus1-1
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus1-2
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus1-3
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus1-4
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus2-1
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus2-2
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus2-3
add bridge=bridge1 comment=defconf ingress-filtering=no interface=qsfpplus2-4
add bridge=bridge1 comment=defconf ingress-filtering=no interface=sfp-sfpplus1
add bridge=bridge1 comment=defconf ingress-filtering=no interface=sfp-sfpplus2
add bridge=bridge1 comment=defconf ingress-filtering=no interface=sfp-sfpplus3
add bridge=bridge1 comment=defconf frame-types=admit-only-vlan-tagged ingress-filtering=no interface=sfp-sfpplus4
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether46,ether47,ether48,ether49 vlan-ids=12
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether45,ether46,ether47,ether48 vlan-ids=13
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48,ether45,ether46 vlan-ids=14
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48,ether45,ether46 vlan-ids=20
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48,ether45,ether46 vlan-ids=90
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48,ether45,ether46 vlan-ids=99
add bridge=bridge1 tagged=qsfpplus1-1,qsfpplus1-2,qsfpplus1-3,qsfpplus1-4,qsfpplus2-1,qsfpplus2-2,qsfpplus2-3,qsfpplus2-4,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus4,ether47,ether48,ether45,ether46 vlan-ids=100
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=ether9 list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface=ether17 list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface=ether23 list=LAN
add interface=ether24 list=LAN
add interface=ether25 list=LAN
add interface=ether26 list=LAN
add interface=ether27 list=LAN
add interface=ether28 list=LAN
add interface=ether29 list=LAN
add interface=ether30 list=LAN
add interface=ether31 list=LAN
add interface=ether32 list=LAN
add interface=ether33 list=LAN
add interface=ether34 list=LAN
add interface=ether35 list=LAN
add interface=ether36 list=LAN
add interface=ether37 list=LAN
add interface=ether38 list=LAN
add interface=ether39 list=LAN
add interface=ether40 list=LAN
add interface=ether41 list=LAN
add interface=ether42 list=LAN
add interface=ether43 list=LAN
add interface=ether44 list=LAN
add interface=ether45 list=LAN
add interface=ether46 list=LAN
add interface=ether47 list=LAN
add interface=ether48 list=LAN
add interface=ether49 list=LAN
add interface=qsfpplus1-1 list=LAN
add interface=qsfpplus1-2 list=LAN
add interface=qsfpplus1-3 list=LAN
add interface=qsfpplus1-4 list=LAN
add interface=qsfpplus2-1 list=LAN
add interface=qsfpplus2-2 list=LAN
add interface=qsfpplus2-3 list=LAN
add interface=qsfpplus2-4 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.42.43/24 comment=defconf interface=ether2 network=192.168.42.0
set servers=8.8.8.8
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.42.58
/system identity
set name="MikroTik 1"
/system routerboard settings
set boot-os=router-os
DeepB
Tue Jun 28, 2022 4:12 pm
As far as i am aware simple VLAN should be L2 only and run exclusively on the switch chip?
EDIT: current profile:
33% bridging
15% management
100% total
43% unclassified
0% routing
7,5% networking
biomesh
Long time Member
Long time Member
Tue Jun 28, 2022 4:24 pm
- you don't need vlan interfaces on a switch unless you are going to implement l3hw offloading (and perform routing) or want to assign an ip address for management to one of the vlans going through/to the switch (this vlan would be assigned to the bridge)
- your ip address is assigned to ether2 and not the bridge/vlan interface on the bridge for management
- most of your ether ports don't have a vlan assigned unless you plan on just using vlan 1 untagged, which would be the default
I would look through
https://wiki.mikrotik.com/wiki/Manual:C ... s_switches
and double check your config. It looks like you missed some steps and added those vlan interfaces unnecessarily unless your goal was l3hw offloading.
DeepB
Tue Jun 28, 2022 4:48 pm
how do i correct that best? is it enough if I delete the bridge? are the coresponding vlans deleted to? or do I need to totaly factory reset the switch?
thanks
Daniel
biomesh
Long time Member
Long time Member
Tue Jun 28, 2022 5:12 pm
I would not start over - here is a sample config for reference:
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no name=bridge1 priority=0x2000 \
    pvid=75 vlan-filtering=yes
set [ find default-name=ether1 ] l2mtu=9080 mtu=9000
set [ find default-name=ether2 ] l2mtu=9080 mtu=9000
set [ find default-name=ether3 ] l2mtu=9080 mtu=9000
set [ find default-name=ether4 ] l2mtu=9080 mtu=\
    9000
set [ find default-name=ether5 ] l2mtu=9080 mtu=\
    9000
set [ find default-name=ether6 ] l2mtu=9080 mtu=9000
set [ find default-name=ether7 ] l2mtu=9080 mtu=9000
set [ find default-name=ether8 ] l2mtu=9080 mtu=9000
set [ find default-name=ether9 ] l2mtu=9080 mtu=\
    9000
set [ find default-name=ether10 ] l2mtu=9080 mtu=9000
set [ find default-name=ether11 ] l2mtu=9080 mtu=9000
set [ find default-name=ether12 ] l2mtu=9080 mtu=9000
set [ find default-name=ether13 ] l2mtu=9080 mtu=9000
set [ find default-name=ether14 ] l2mtu=9080 \
    mtu=9000
set [ find default-name=ether15 ] l2mtu=9080 mtu=9000
set [ find default-name=ether16 ] l2mtu=9080 mtu=9000
set [ find default-name=ether17 ] l2mtu=9080 mtu=9000
set [ find default-name=ether18 ] l2mtu=9080 mtu=9000
set [ find default-name=ether19 ] l2mtu=9080 mtu=9000
set [ find default-name=ether20 ] l2mtu=9080 mtu=9000
set [ find default-name=ether21 ] l2mtu=9080 mtu=9000
set [ find default-name=ether22 ] l2mtu=9080 mtu=9000
set [ find default-name=ether23 ] l2mtu=9080 mtu=9000
set [ find default-name=ether24 ] l2mtu=9080 mtu=9000
set [ find default-name=sfp-sfpplus1 ] l2mtu=9080 mtu=9000
set [ find default-name=sfp-sfpplus2 ] l2mtu=9080 mtu=9000
/interface vlan
add interface=bridge1 mtu=9000 name=vlan75 vlan-id=75
add bridge=bridge1 interface=ether1 internal-path-cost=4 path-cost=4
add bridge=bridge1 frame-types=admit-only-untagged-and-priority-tagged \
    interface=ether4 internal-path-cost=4 path-cost=4 pvid=500
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether5 \
    internal-path-cost=4 path-cost=4 pvid=100
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether6 \
add bridge=bridge1 interface=ether7 internal-path-cost=4 path-cost=4 pvid=100
    interface=ether8 internal-path-cost=4 path-cost=4 pvid=100
    interface=ether9 internal-path-cost=4 path-cost=4 pvid=500
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=ether10 \
    internal-path-cost=4 path-cost=4 pvid=400
add bridge=bridge1 interface=ether11 internal-path-cost=4 path-cost=4 pvid=\
    400
    interface=ether12 internal-path-cost=4 path-cost=4 pvid=500
add bridge=bridge1 interface=ether13 internal-path-cost=4 path-cost=4 pvid=70
    interface=ether14 internal-path-cost=4 path-cost=4 pvid=100
    interface=ether15 internal-path-cost=4 path-cost=4 pvid=500
    interface=ether16 internal-path-cost=4 path-cost=4 pvid=100
add bridge=bridge1 interface=ether17 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether18 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether19 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether20 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether21 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether22 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether23 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether24 internal-path-cost=4 path-cost=4 pvid=75
add bridge=bridge1 frame-types=admit-only-vlan-tagged interface=sfp-sfpplus1 \
    internal-path-cost=2 path-cost=2
add bridge=bridge1 interface=sfp-sfpplus2 internal-path-cost=2 path-cost=2
add bridge=bridge1 interface=ether2 internal-path-cost=4 path-cost=4
add bridge=bridge1 interface=ether3 internal-path-cost=4 path-cost=4
add bridge=bridge1 tagged=sfp-sfpplus1 untagged=ether13 vlan-ids=70
add bridge=bridge1 tagged=sfp-sfpplus1,bridge1 untagged=ether24 vlan-ids=75
add bridge=bridge1 tagged=sfp-sfpplus1,ether5,ether6 untagged=\
    ether8,ether7,ether16,ether14 vlan-ids=100
add bridge=bridge1 tagged=sfp-sfpplus1,ether10 untagged=ether11 vlan-ids=400
add bridge=bridge1 tagged=sfp-sfpplus1,ether6,ether13 untagged=\
    ether9,ether12,ether4,ether15 vlan-ids=500
add address=192.168.75.3/24 interface=vlan75 network=192.168.75.0
set servers=192.168.75.1
add dst-address=0.0.0.0/0 gateway=192.168.75.1
/system ntp client
set enabled=yes
/system ntp client servers
add address=pool.ntp.org
chechito
Tue Jun 28, 2022 5:34 pm
please avoid using MGMT eth interface
if you wat to use L3 HW offload check this
https://help.mikrotik.com/docs/display/ ... onExamples
DeepB
Tue Jun 28, 2022 7:19 pm
I do NOT want to use L3 anything.
I did a factory reset. (System --> Reset configuration). After reboot I changed the admin password. I did not do anything else at all.
CPU: 100%
No VLANs no nothing. That cant be normal, right?
kreload
Tue Jun 28, 2022 7:53 pm
You are using CPU for all VLANS. Usually you need the CPU only for management vlans.
Change this:
/interface vlan
to :
/interface vlan
Users browsing this forum: GoogleOther [Bot], jaclaz, Tony93, vagrik and 124 guests
