MDZT
LDF LTE6 Kit - Off line
Tue Jun 28, 2022 3:58 pm
I'm new to the forum and starting with Mikrotik products.
I just bought a RB2011Uias-RM router and a LDF LTE6 kit.
Following various manipulations I lost the Web and Winbox access of my LDF LTE6 kit.
During normal startup, the 4 lights are on, but the network card connects and disconnects.
I managed to start it in Netboot mode, launched Netinstall, I can see my LTE6, I try to flash it with routeros-mipsbe-7.3.1.npk (current version) and the option "Apply defaut config" but :
- it seems to transmit the file well (install then ready)
- the light remains blue and the software indicates ready.
- the reboot button does not appear
- if I unplug nothing has changed
I thank you in advance for your help
NB: I wanted to activate the IP V6 package (origin of the bug)
MDZT
Re: LDF LTE6 Kit - Off line
Tue Jun 28, 2022 5:46 pm
screenshot of Netinstall
MDZT
Thu Jun 30, 2022 8:23 am
Is there a way to access this equipment when it is in Netboot mode to solve this problem?
Is it possible to connect to the card with a serial terminal or something else?
None of the reset procedures work.
Thanks for your help
MDZT
Re: LDF LTE6 Kit - Off line  [SOLVED]
Sat Jul 02, 2022 8:22 am
Hello to all of you,
Following the answer of the MIKROTIK hotline, my problem is solved.
The model : RBLDFR can only be updated to the version : RouterOS 6.48.6 Long Term.
The more recent firmware does not seem to be compatible.
Sincerely,
This subject is therefore resolved and therefore closed
Users browsing this forum: Ahrefs [Bot], sid5632 and 172 guests
