cfrancisbascon
my Hex S doesn't appear in Winbox neighbor tab
Wed Jun 29, 2022 8:35 pm
my Hex S doesn't appear in Winbox neighbor tab, I cannot access my router
If anyone have an idea what is wrong with my router, Please help, I would be grateful.
Thanks in advance
rextended
Re: my Hex S doesn't appear in Winbox neighbor tab
Wed Jun 29, 2022 8:51 pm
You do not provide any relevant detail, then use netinstall.
Why do you assume from the start that the problem is not your computer?
cfrancisbascon
Thu Jun 30, 2022 9:52 pm
my router is working okay at first but, after I the reset, its not showing on winbox neighbor tab.
what happen is, I reset my router because I forgot the login information, preventing me accessing its settings
yes i used netinstall, but even netinstall cannot detect my router, while my other one is detected
i have two mikrotik router, the other one is working okay, i can see it on my winbox neighbor tab
rextended
Thu Jun 30, 2022 10:01 pm
you try ether2 for winbox?
cfrancisbascon
Thu Jun 30, 2022 10:06 pm
I really appreciate for replying
I'm new in mikrotik, started using it month ago,
its working okay, i learn and do configuration with the help of youtube tutorials
current setup to access my router:
Lan cable is connected on hex S eth2 port, and to my pc directly
manually input, no dhcp
pc IP address: 192.168.88.5
subnet: 255.255.255.0
i access my router with mac address, but now, i cannot access because its not showing on winbox neighbor tab
If you need more detail please tell me, thank you
Last edited by cfrancisbascon on Thu Jun 30, 2022 10:09 pm, edited 1 time in total.
rextended
you try to open 192.168.88.1 with winbox?
if you can open new terminal on some way, paste this inside your router terminal:
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
rextended
Thu Jun 30, 2022 10:14 pm
This mean that you successfully netinstall another router, or simply you see with winbox the other router?
cfrancisbascon
Thu Jun 30, 2022 10:19 pm
/tool mac-server
set enabled=yes
yes I tried opening 192.168.88.1 on winbox, but could not connect.
cfrancisbascon
Thu Jun 30, 2022 10:21 pm
I did not netinstall router, I just see the router in netinstall, also I can access the other router with winbox
edit: you mean putting the router to netinstall mode, yes I did that with the help of youtube and mikrotik wiki
Last edited by cfrancisbascon on Thu Jun 30, 2022 10:25 pm, edited 1 time in total.
bpwl
Thu Jun 30, 2022 10:23 pm
On the hEX S .... config
- Neighbor discovery could be off in Discovery Configuration. (https://wiki.mikrotik.com/wiki/Manual:I ... _discovery) It changed somewhat: https://help.mikrotik.com/docs/display/ ... +discovery
- Tools "MAC Winbox" not allowed on that interface ? https://help.mikrotik.com/docs/display/ROS/MAC+server
- Both devices not in the same (L2 network) broadcast domain ?
cfrancisbascon
Thu Jun 30, 2022 10:49 pm
- I did several reset on the hex S, I think Neighbor discovery is reset too, but im not sure
- I cannot, access hex s terminal, so i don't know how to check if its allowed or not
lets label two rotuer as ,router1 and router2
router1 is the working router
router2 is the problem router, can't be seen in winbox
- currently I used one lan cable to test the two router, when Im done test with router1, I remove/disconnect the lan cable then connect it to router2,
rextended
Re: my Hex S doesn't appear in Winbox neighbor tab  [SOLVED]
Fri Jul 01, 2022 12:27 am
you have tried to connect winbox with the mac specified on the label where router model and serial number is also present?
try netinstall, but keep pressing the reset button for more than one minute and check if appear on netinstall
if all this fail, probably your protected-routerboot function is engaged, and when you reset the configuration the routerboard
can not go on netinstall mode, until you do not guess protect-routerboard timer, usually for default or 20 or 30 seconds, depend on bios version....
cfrancisbascon
Fri Jul 01, 2022 9:31 am
this works,
I press reset button like 40 to 45 seconds, and boom, device shows on netinstall
thank you very much
Users browsing this forum: Google [Bot] and 102 guests
