kalamaja
Will there be newer CHR AMI in AWS Marketplace?
Thu Jun 30, 2022 9:28 am
Current version is Ver 6.44.3 which can be upgraded to latest v6 and v7, but it will be removed on July 30, 2022:
We have identified that you have launched one or more instances in the last month using a public AMI which will be deprecated on July 30, 2022. While you will continue to be able to launch instances using the AMI IDs, the AMIs will not be visible on the public AMI catalog [3] or in DescribeImages calls by default once deprecated. To list deprecated AMIs in the DescribeImages API calls, you must specify the --include-deprecated parameter [4]. If you would like to view details about the deprecated AMI, you can describe it using its ID as well. This message is to notify you of the upcoming change, and does not require any action from you.
The following is a list of old public AMIs you have used for instance launches in the last month in the EU-NORTH-1 Region :
ami-d770f8a9
https://aws.amazon.com/marketplace/pp/p ... MPContessa
Users browsing this forum: Bing [Bot] and 131 guests
