robertbruce1983
Vlans
Thu Jun 30, 2022 11:39 am
Good morning
can you please help, i am new to Mikrotik switches, i current have a setup of Unifi kit on site. I have around 25 switches in total.
Cloud Router Switch - CRS-317-1G-16S+
I am setting up this to try and resolve a wifi issue
The current setup has multiple VLANS, i have replicated these vlans on the new mikrotik switch, what i am finding it hard to work out is how to assign multiple Vlans to the same port
On the current unifi switches i have trunk ports that feed fibre connections to feedar pillars around the grounds, these trunk ports have 4 vlans setup on each. how can i replicate this on the Mikrotik?
There are some ports that i have just a single VLAN on, this doesnt look to be an issue
On the VLAN settings menu what do i need to select for the Interface, is this the interface that the VLAN will be assigned to?
Thank you
k6ccc
Re: Vlans
Fri Jul 01, 2022 6:43 am
Are you using SwitchOS or RouterOS? That device can use either one.
Users browsing this forum: dsfak, intania, miker3000, zalciukaz and 118 guests
