antoxic
ROS7: Firewall rule trigerring incorrectly
Thu Jun 30, 2022 12:14 pm
Hi.
I'm running RouterOS 7.3.1 on a RB5009.
I have 2 DNS servers at home and I want to log the DNS requests from all the IP addresses except those two servers. In the firewall, I have created the two following rules:
add action=accept chain=forward dst-port=53 log=yes log-prefix=_dns2 out-interface=vlan1609-spf1-ptp-dvblab protocol=udp \
    src-address=!192.168.69.2
add action=accept chain=forward dst-port=53 log=yes log-prefix=_dns3 out-interface=vlan1609-spf1-ptp-dvblab protocol=udp \
    src-address=!192.168.69.3
From what I understand, those rules should accept and log all the traffic to the udp port 53 coming from any IP except 192.168.69.2 and 192.168.69.3. But in the logs i get the following messages:
 11:07:56 firewall,info _dns3 forward: in:vlan69-data out:vlan1609-spf1-ptp-dvblab, src-mac 6e:dd:5f:40:06:68, proto UDP, 192.168.69.2:55996->8.8.8.8:53, len 71
 11:07:56 firewall,info _dns3 forward: in:vlan69-data out:vlan1609-spf1-ptp-dvblab, src-mac 6e:dd:5f:40:06:68, proto UDP, 192.168.69.2:51263->9.9.9.9:53, len 71
 11:09:57 firewall,info _dns3 forward: in:vlan69-data out:vlan1609-spf1-ptp-dvblab, src-mac 6e:dd:5f:40:06:68, proto UDP, 192.168.69.2:27622->8.8.8.8:53, len 71
 11:09:57 firewall,info _dns3 forward: in:vlan69-data out:vlan1609-spf1-ptp-dvblab, src-mac 6e:dd:5f:40:06:68, proto UDP, 192.168.69.2:27373->9.9.9.9:53, len 71
Looks like the firewall rule is ignoring the ! in front of the ip addresses, or, am I wrong?
Thanks in advance.
Regards
eworm
Re: ROS7: Firewall rule trigerring incorrectly
Thu Jun 30, 2022 12:26 pm
This is correct... Each rule excludes one address, but the other one allows it nevertheless.
antoxic
Thu Jun 30, 2022 12:28 pm
Oh, silly me, now I get it! Thank you very much! I will make an address list with both servers and put them into a single rule.
eworm
Thu Jun 30, 2022 12:29 pm
You could try something like this:
/ip/firewall/address-list/add list=dns-server address=192.168.69.2
/ip/firewall/address-list/add list=dns-server address=192.168.69.3
/ip/firewall/filter/add action=accept chain=forward dst-port=53 log=yes log-prefix=_dns out-interface=vlan1609-spf1-ptp-dvblab protocol=udp src-address-list=!dns-server
antoxic
Thu Jun 30, 2022 6:37 pm
Yes, excatly! Works like a charm! Thanks
Users browsing this forum: arebelo, Bing [Bot], jaclaz, maciejl and 90 guests
