gdanov
interface TX/RX stats reset when?
Thu Jun 30, 2022 12:25 pm
I'm trying to figure out my internet consumption and have forgotten to enable graphs.
looking at the Ethernet interface stats I see total RX/TX, but I'm not sure when that's reset.
my modem (linked via ethernet port to my MT) restarts each night, so the link goes down every 24h, but the MT interface/device stays up all the time. So, the TX/RX stats are reset upon link up/down or upon router restart?
erlinden
Re: interface TX/RX stats reset when?
Thu Jun 30, 2022 12:30 pm
As far as I know:
  • Counter reset
  • Interface disable/enable
  • reboot
And there might be more...
pe1chl
Thu Jun 30, 2022 12:33 pm
No, interface counters are only reset on reboot. And they cannot be reset manually.
Only when you have a dynamic interface that would be removed when the link is down, e.g. an L2TP client, it would be reset.
gdanov
Thu Jun 30, 2022 12:35 pm
that's my guess too. enable/disable resets the stat but link up/downs doesn't reset the stat.
gdanov
Thu Jun 30, 2022 12:36 pm
thanks
erlinden
Thu Jun 30, 2022 12:46 pm
Then what is the purpose of the "Reset Counters" button, pe1chl?
rextended
Thu Jun 30, 2022 1:06 pm
Is a true question, or is just a polemic one?
The button "Reset Counters" on ethernet interface is only for reset Overall Stat / RX Stat / TX Stat (when is supported on the model)
not for Status (link down) or Traffic (Bytes/Packets/Drops).
And YES, on the first times I use that button, I'm expecting that reset all counters, traffic and drops included, but I have learn that is not work on that way...
chechito
Thu Jun 30, 2022 8:45 pm
try reset-counters on specific interface by CLI
example on 6.48.6
rextended
Thu Jun 30, 2022 8:59 pm
do not mix
/interface reset-counters ether1 # (button do not exist)
with
/interface ethernet reset-counters ether1 # (the button "Reset Counters")
Users browsing this forum: Bing [Bot], complexxL9, sotahe9145, tdw and 203 guests
