krstan
Is there a way to hide static ip or public ip address? - MikroTik
Fri Jul 01, 2022 4:50 am
Hi, Can mikrotik router hide our public ip address given to us by our ISP? It's an emergency
thank you very much
rextended
Re: Is there a way to hide static ip or public ip address? - MikroTik
Fri Jul 01, 2022 10:18 am
Obviously NO, it's like you want to hide your address from the courier you just asked to bring you the pizza...
Use a VPN for this, it's like someone is ordering pizza for you and bringing it to you after the courier delivers it to him.
erlinden
Fri Jul 01, 2022 10:19 am
You might want to give some additional information. DO you i.e. want to prevent users from browsing to https://www.whatismyip.com/ ? Or do you mean something differently?
Better question...why?
normis
Fri Jul 01, 2022 2:16 pm
Yes:
1) why
2) hide from whom?
krstan
Fri Jul 01, 2022 11:59 pm
I need to hide the address due to repeated attack
The attack cannot be stopped from inside the server
The attack sends more than 40,000 packets
icmp attack type
The address causing the attack is usually variable like 181.214.147.132
or 181.214.147,146
I disabled the protocol ( udp-tcp-icmp)
Via filter input
The attack was not prevented though
rextended
Sat Jul 02, 2022 12:05 am
Is useless hide the IP, still exist...
Ask your ISP another IP or ask your ISP to block the attack before reaching your device...
krstan
Sun Jul 03, 2022 1:07 am
You have contacted the provider
He changed the IP address
This does not help stop the attack
Techsystem
Wed Sep 21, 2022 10:05 pm
Yes:
1) why
2) hide from whom?
Hello Normis..! Please advise how ..?
rextended
Wed Sep 21, 2022 10:27 pm
@Techsystem:
"why" and "whom" are two question, and the "yes" is the confirmation that the two question must be answered.
Without context simply: use a VPN.
Users browsing this forum: Google [Bot] and 78 guests
