alberto464
DHCP doesn't work when LTE not connected
Sat Jul 02, 2022 1:36 pm
I noticed a problem with my configuration: when the data SIM is not connected to the internet, the MikroTik does not assign an IP address via DHCP to the machine connected to the ethernet port 1.
Is this common with the MikroTik or does it depend on how we have configured it? Can you help me?
# jun/29/2022 23:11:04 by RouterOS 7.3
# software id = 3PWC-R7A2
# model = RBwAPR-2nD
add name=bridge1 protocol-mode=none
/interface lte
set [ find ] allow-roaming=no band="" name=lte1 network-mode=3g,lte
set [ find default-name=ether1 ] arp=proxy-arp
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface lte apn
set [ find default=yes ] apn=xxx.vodafone.it authentication=pap ip-type=ipv4 name=LTE use-network-apn=no user=LTERES_111943D
add name=dhcp-pool ranges=192.168.88.101-192.168.88.199
add address-pool=dhcp-pool interface=bridge1 name=dhcp
add bridge=bridge1 interface=wlan1
/ip settings
set tcp-syncookies=yes
add address=192.168.88.1/24 interface=bridge1 network=192.168.88.0
add address=82.100.200.100/24 interface=ether1 network=82.100.200.0
/ip dhcp-server lease
add address=192.168.88.2 client-id=1:14:49:bc:26:d7:XX comment="Router One" mac-address=14:49:BC:26:D7:32 server=dhcp
add address=192.168.88.0/24 dns-server=1.1.1.1,8.8.8.8,8.8.4.4 gateway=192.168.88.1 netmask=24 ntp-server=193.204.114.232,193.204.114.233
set servers=8.8.8.8,1.1.1.1
add action=masquerade chain=srcnat comment="Navigazione Rete Lan" out-interface=lte1 src-address=192.168.88.0/24
add action=dst-nat chain=dstnat comment="Router One" dst-port=44063 protocol=tcp to-addresses=192.168.88.2 to-ports=44063
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=93.175.000.000/32,192.168.0.0/16
set ssh disabled=yes
set api disabled=yes
set winbox address=93.175.000.000/32,192.168.0.0/16
set api-ssl disabled=yes
/system ntp client
set enabled=yes
/system ntp client servers
add address=193.204.114.232
add address=193.204.114.233
/tool graphing interface
add
/tool sms
set port=lte1
rextended
Re: DHCP doesn't work when LTE not connected
Sat Jul 02, 2022 3:29 pm
Probably is proxy-arp on ether1 (at lesat must be on bridge...)
Perché hai attivato i syncookies? Spesso danno fastidio a connessioni lecite, ma con il dhcp non c'entrano niente.
/ip settings
IP 82.x.x.x on ether1?
This also must be on bridge....
alberto464
Tue Jul 05, 2022 6:02 pm
I tried, but nothing has changed.
/ip settings
I have disabled them as suggested by you. So better leave them off.
Maybe the problem is this, if I assign it to bridge1, can I also leave the pool of IP 192.168.xx.xx assigned to the bridge?
rextended
Tue Jul 05, 2022 7:34 pm
You can add any IP to the master interface, but you must not put IPs on slave interfaces.
Users browsing this forum: mstanciu and 27 guests
