BrateloSlava
How to filter routes that are advertised via OSPF?
Sun Jul 03, 2022 10:42 am
There are several networks, that are connected via L2TP/SSTP/IPIP/etc. OSPF configured. ROS 7.3.1 Everything is fine. Some routers redistribute their static routes.
Question: how can I set up filtering of these advertised routes on some routers?
For example: there is a router R1 that redistributes routes to addresses 1.1.1.1, 2.2.2.2, 3.3.3.3. And there is a router R2 that does not need such routes through R1 to 1.1.1.1 and 2.2.2.2.
On R2 tried to filter:
/routing filter rule add chain=ospf-in comment="Test block" disabled=no rule="if ( protocol ospf && dst in 1.1.1.1 ) { reject }"
But such a filter generally breaks the entire OSPF on this router.
paolobyte
Re: How to filter routes that are advertised via OSPF?
Sun Jul 03, 2022 4:50 pm
I'm curious.. How does it "break" ospf? Does adjacency drop? Or just all OSPF routes disappear?
BrateloSlava
Sun Jul 03, 2022 5:52 pm
Special for you. :D
aleksis
Re: How to filter routes that are advertised via OSPF?  [SOLVED]
Mon Jul 04, 2022 11:25 am
Filter default action is 'reject'.
rule="if ( protocol ospf && dst in 1.1.1.1 ) { reject } else { accept }"
BrateloSlava
Mon Jul 04, 2022 2:12 pm
It's really simple... Thank you.
Users browsing this forum: No registered users and 22 guests
