zorrua
Zerotier compatible devices
Sun Jul 03, 2022 11:05 am
I have one RB3011 and two RB2011 hat want to connect with Zerotier.
Are thoose devices supported for Zerotier? I can not find any config related to zt in the web interface, I am using 7.3.1 version on all of them.
Best regards.
Jotne
Re: Zerotier compatible devices  [SOLVED]
Sun Jul 03, 2022 12:18 pm
From this page:
https://help.mikrotik.com/docs/display/ROS/ZeroTier
MikroTik has added ZeroTier to RouterOS v7.x as a separate package for the ARM/ARM64 architecture. (only)
So look at this page:
https://mikrotik.com/products/matrix
And you see
RB3011 ARM 32bit
RB2011 MIPSBE
And you need to download the ZeroTier package from here: https://mikrotik.com/download
Get the extra package for your architecture "ARM". Extract it and copy ZeroTier to the router. Reboot.
zorrua
Sun Jul 03, 2022 11:38 pm
Thank you very much!
I installed the extra package and now I have working ZeroTier in the router!
Is there any plan to get ZT running in MIPSBE platform?
Kind regards.
Jotne
Mon Jul 04, 2022 8:01 am
Users browsing this forum: maldridge and 103 guests
