omega-00
Dynamic Upnp rules, how long?
Tue Sep 25, 2007 5:09 am
Just wanting to know what the standard timeout for Upnp generated rules is, and if there is anyway to set a timeout on these?
gustkiller
Re: Dynamic Upnp rules, how long?
Tue Sep 25, 2007 9:51 pm
i have the same doubt!
omega-00
Thu Sep 27, 2007 5:05 am
I just want to make sure if I'm allowing upnp for my users that these rules aren't just going to accumulate over time.
JmJ17
Mon Oct 08, 2007 3:33 am
I would like to know if uPnP works in v2.9.x because my devices doesn't see the router as uPnP... :(
omega-00
Mon Oct 08, 2007 5:28 am
It does, I have a windows box at home that detects mine fine.
Just start with no firewall rules and ensure you can pick it up (to make sure you have it set up correctly to start with ;-) )
omega-00
Mon Oct 15, 2007 3:04 am
*bump*
Would also like a mt reply on the following: Will upnp timeout settings be a possibility for v3? (assuming there isn't a timeout currently which is what it looks like)
sergejs
Mon Oct 15, 2007 4:24 pm
There is no timeout and there is not option to configure that.
UPnP implementation has commands to add rule and remove rule.
samotoka
Wed Oct 31, 2007 3:43 pm
hello friends
same problem
Yes i use utorrent too
utorrent send command and MT make dynamic rule - that is correct - but utorrent DON`T send command to release the port
NOW we need script
come on
Any suggestions are welcome
dadaniel
Fri May 14, 2010 11:52 pm
Is there a solution now?
