I'm trying to separate my home network into 3 VLANs with the IDs 30, 20, 10. I've set-up the Unifi AP to broadcast 3 SSIDs which also have VLAN IDs 30, 20, 10. That AP is connected on eth4 on my RB5009. Let's assume all devices on the VLANs will connect through the AP for now.
I can successfully connect wirelessly to each one of those SSIDs, get an IP address from DHCP and access the Internet.
The problem is that the firewall somehow fails to block cross-VLAN traffic (no VLAN isolation). For example:
While on device with the address 192.168.30.2 I ping 192.168.20.2 - and while I expected it to fail, the ping proceeds successfully. If I monitor the ping exchange in Torch and collect the VLAN Id while it goes on, there's no VLAN Id in the results row where the "Src: 192.168.30.2, Dst: 192.168.20.2" connection is shown. So perhaps that's a symptom.
I've also looked at the firewall rules and the key ones for isolation should be (taken from my .rsc at the bottom of this post):
Code: Select all
add action=accept chain=forward comment="vlan to wan traffic" \
connection-state=new in-interface-list=VLANS out-interface-list=WAN
connection-state=invalid
My problem looks very similar to what's described below this code block https://help.mikrotik.com/docs/display/ ... ter_198473 . I've read viewtopic.php?f=23&t=143620 (and respective .rsc files) and the Bridge VLAN Table manual but I haven't been able to apply the information from there to fix my problem.
Could somebody please share their thoughts on why this could be happening?
Code: Select all
# jul/03/2022 18:21:16 by RouterOS 7.3.1
# software id = FZWK-5BAJ
# model = RB5009UG+S+
# serial number = HC907M8KM80
add admin-mac=DC:2C:6E:DD:8B:A8 auto-mac=no comment=defconf name=bridge \
vlan-filtering=yes
# disable unused ifaces
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] disabled=yes
/interface vlan
add interface=ether4 name=company-vlan vlan-id=30
add interface=ether4 name=dev-vlan vlan-id=20
add interface=bridge name=home-vlan vlan-id=10
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=VLANS
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-256 \
hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-gcm pfs-group=modp2048
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add name=company ranges=192.168.30.2-192.168.30.254
add name=dev ranges=192.168.20.2-192.168.20.254
add name=home ranges=192.168.10.2-192.168.10.254
add address-pool=dhcp interface=bridge name=defconf
add address-pool=company interface=company-vlan name=company-dhcp
add address-pool=dev interface=dev-vlan name=dev-dhcp
add address-pool=home interface=home-vlan name=home-dhcp
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
set discover-interface-list=none
/interface bridge vlan
add bridge=bridge tagged=ether4,bridge vlan-ids=10
add bridge=bridge tagged=bridge,ether4 vlan-ids=20
add bridge=bridge tagged=bridge,ether4 vlan-ids=30
/interface l2tp-server server
set use-ipsec=yes
add interface=company-vlan list=VLANS
add interface=dev-vlan list=VLANS
add interface=home-vlan list=VLANS
add interface=company-vlan list=LAN
add interface=dev-vlan list=LAN
add interface=home-vlan list=LAN
/interface ovpn-server server
set auth=sha1,md5
/interface sstp-server server
set default-profile=default-encryption
192.168.88.0
add address=192.168.30.1/24 interface=company-vlan network=192.168.30.0
add address=192.168.20.1/24 interface=dev-vlan network=192.168.20.0
add address=192.168.10.1/24 interface=home-vlan network=192.168.10.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.248 mac-address=E4:5F:01:6E:28:C2 server=defconf
add address=192.168.10.0/24 dns-server=192.168.88.1 gateway=192.168.10.1
add address=192.168.20.0/24 comment=me dns-server=192.168.88.1 gateway=\
192.168.20.1
add address=192.168.30.0/24 comment=company dns-server=192.168.88.1 gateway=\
192.168.30.1
192.168.88.1
set allow-remote-requests=yes
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input dst-port=443,80 protocol=tcp
in-interface-list=!LAN
invalid
/ip ipsec policy
set 0 proposal=*1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=8080
set ssh disabled=yes
set api disabled=yes
set winbox disabled=yes
set api-ssl disabled=yes
/ip ssh
set strong-crypto=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ppp secret
add name=vpn
/system clock
set time-zone-name=Europe/Warsaw
/system routerboard settings
set cpu-frequency=1400MHz
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
