jcarrieres
Dead CCR1036
Mon Jul 04, 2022 6:02 am
Good day, im having a good round of trouble trying to resurrect a dead CCR1036-8G-2S+
i have netinstall running, but as soon as the router gets a bootp signal, it receives an image and crashes
trying bootp protocol.................................................................................................................. OK
Got IP address: 192.168.15.3
resolved mac address 04:D9:F5:06:DF:3A
transfer started ................................. transfer ok, time=0.77s
setting up elf image... OK
jumping to kernel code
(0,0) hv_panic: corrupt hvfs: computed CRC 0x63fa682b, trailer CRC 0x245abf9b
(0,0) hv_panic: fatal DTSB read miss, fault addr 0
(0,0) fatal: invalid CPA for page 0
(0,0) Saved register dump:
(0,0) r0  0000_0000_0000_0000  r10 0000_0000_0000_0000  r20 ffff_fffc_0013_715c
(0,0) r1  0000_0000_0000_0000  r11 0000_0000_0000_0008  r21 ffff_fffc_0013_7158
(0,0) r2  ffff_fffc_0003_1ea8  r12 ffff_ffff_ffff_ffff  r22 ffff_fffc_0002_ad68
(0,0) r3  ffff_fffc_0010_e7c8  r13 0000_003f_fff0_007f  r23 ffff_fffc_0002_bfe8
(0,0) r4  ffff_fffc_0004_2d90  r14 ffff_fffc_0013_0abe  r24 ffff_fffc_0010_e668
(0,0) r5  ffff_fffc_0012_ab50  r15 0000_0000_0000_005f  r25 ffff_fffc_0010_e650
(0,0) r6  0000_0000_0000_1000  r16 0000_0003_679c_902a  r26 ffff_fffc_0010_e658
(0,0) r7  0000_0000_0000_0080  r17 0000_0000_0000_0001  r27 ffff_fffc_0010_e610
(0,0) r8  0000_0000_0000_2600  r18 0000_0000_0000_0780  r28 ffff_fffc_0010_e600
(0,0) r9  ffff_fffc_0016_3018  r19 0000_0000_0000_0280  r29 ffff_fffc_0010_e618
(0,0) lr  0000_0000_0000_0000  sp  ffff_fffc_0003_3010
(0,0) im  0000_003f_fff0_007f  ex0 ffff_fffc_0000_5a20  ex1 0000_0000_0000_0003
installed OS is corrupted so it doesnt boot normally.
i have allready tested a bunch of different versions of netinstall to no avail.
can someone nudge me in te right direction?
thanks in advance
rextended
Re: Dead CCR1036
Mon Jul 04, 2022 2:03 pm
nz_monkey
Re: Dead CCR1036
Mon Jul 04, 2022 3:07 pm
Check the C10 and C11 capacitors on the PSU board, they are at the bottom near the mosfet heatsink. If they are leaking, that is your problem.
rextended
Re: Dead CCR1036
Mon Jul 04, 2022 3:51 pm
The green capacitor stikes again...
rextended
Re: Dead CCR1036
Mon Jul 04, 2022 3:52 pm
C10 damaged...
rextended
Re: Dead CCR1036
Mon Jul 04, 2022 3:53 pm
It can be seen badly, but it is swollen, domed above and below it is raised above the base.
I haved the same problem on same device,
but solved replacing totally the PSU with another identical,
but I do not have fixed and tested the old.
Users browsing this forum: No registered users and 170 guests
