I configurred openvpn on mikrotik and installed client on windows 10.
I am able to connect fine with clients and access hosts on the LAN, but I am unable to reach the outside internet when connected VPN, can ping only 8.8.8.8 but can`t browse google/yahoo etc.
mikrotik config
Code: Select all
# model = 951G-2HnD
# serial number =
add admin-mac=CC:2D:E0:23:97:80 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
country=romania disabled=no distance=indoors frequency=auto mode=\
ap-bridge ssid=XSDCentru_MKT wireless-protocol=802.11
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether2 ] name=ether2-LAN
set [ find default-name=ether3 ] master-port=ether2-LAN
set [ find default-name=ether4 ] master-port=ether2-LAN
set [ find default-name=ether5 ] master-port=ether2-LAN
/ip neighbor discovery
set ether1-WAN discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.200-192.168.1.220
add name=vpn ranges=192.168.89.2-192.168.89.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *0 dns-server=8.8.8.8
set *FFFFFFFE change-tcp-mss=default dns-server=192.168.1.1 local-address=\
192.168.89.1 remote-address=vpn use-compression=yes
add bridge=bridge comment=defconf interface=ether2-LAN
/interface l2tp-server server
set allow-fast-path=yes enabled=yes use-ipsec=yes
add comment=defconf interface=ether1-WAN list=WAN
/interface ovpn-server server
set auth=sha1 certificate=SERVERTEST cipher=aes128,aes256 default-profile=\
default-encryption enabled=yes require-client-certificate=yes
/interface sstp-server server
set default-profile=default-encryption
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=\
ether1-WAN
/ip dhcp-server lease
add address=192.168.1.214 client-id=1:0:17:c8:97:5f:cf comment=KYOCERA \
mac-address=00:17:C8:97:5F:CF server=defconf
add address=192.168.1.207 client-id=1:f0:4d:a2:fd:2c:cb comment=\
"viorica conta" mac-address=F0:4D:A2:FD:2C:CB server=defconf
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.1.1 name=router.lan
established,related,untracked
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow ovpn" dst-port=1194 \
in-interface=ether1-WAN protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=accept chain=input dst-port=80,8291,22 in-interface=all-ppp \
protocol=tcp src-address=192.168.89.0/24
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
ipsec-policy=out,none out-interface-list=WAN src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="masq. vpn traffic" log=yes \
add disabled=yes distance=1 gateway=192.168.5.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.1.0/24,192.168.89.0/24
set ssh address=192.168.1.0/24,192.168.89.0/24
set api disabled=yes
set winbox address=\
192.168.1.0/24,192.168.89.0/24,83.103.130.59/32,90.84.229.149/32
set api-ssl disabled=yes
/ppp secret
add name=vpn profile=default-encryption
add name=joco profile=default-encryption
add name=misu profile=default-encryption service=ovpn
/system clock
set time-zone-name=Europe/Bucharest
/system identity
set name=MikroTik-XSD
/system ntp client
set enabled=yes primary-ntp=89.36.93.8 secondary-ntp=193.22.95.9
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Code: Select all
client
dev tun
proto tcp
remote xxx.xxx.xxx.xxx 1194
resolv-retry infinite
nobind
persist-key
persist-tun
ca ca.crt
cert client.crt
key client.key
remote-cert-tls server
cipher AES-256-CBC
verb 3
auth-user-pass secret.cfg
route 192.168.1.0 255.255.255.0
What is wrong?
