Parsanejad
Simple guide (preferably via WinBox/WebFig) on how to set a NordVPN WireGuard client
Tue Jul 05, 2022 5:49 pm
Okay, I'm not a network-savvy and though I know it's unprofessional but command-line interfaces really scare me, however I find no where else to ask this. So apologies in advance if you're encountering a dumb kiddo in a community of network geeks.
Anyway, I kindly ask if someone can provide an easy guide for a guy who merely wants to configure a WireGuard interface on his RB951Ui-2HnD to tunnel his whole internet traffic through a NordVPN server, preferably using WinBox/GUI or if necessary using some commands but with noob-friendly instructions?
Much appreciation in advance.
anav
Re: Simple guide (preferably via WinBox/WebFig) on how to set a NordVPN WireGuard client
Tue Jul 05, 2022 6:59 pm
No problem,
Please read through this thread to understand wg and MT and then specifically para 7 applies.
viewtopic.php?t=182340
After you give it a decent effort, post your config................
Remember that it works if you cover the bases.
- wireguard parameters
- routes
- firewall rules (incl sourcenat rules)
Parsanejad
Tue Jul 05, 2022 7:38 pm
No problem,
- routes
Thank you for guiding me. I'll give it a try and then will update you. 🙂👍
Users browsing this forum: GoogleOther [Bot], litogorospe and 38 guests
