DoubleDB
Unable to set a local variable
Tue Jul 05, 2022 7:51 pm
:local elem 0;
:local firstsession "";
:foreach sessid in=[/user-manager/session/find where user=testuser] do={
	if ($elem < 1) do={
		:set $firstsession [/user-manager/session/get $sessid started];
		:put message=("First session: ".$firstsession); # Works - shows "jun/11/2022 16:33:32"
		:set $elem 1;
:put message=("User testuser, Session start: ".$firstsession); # Doesn't work - returns empty value
Any ideas why "set" only works within the foreach loop but I'm unable to read it outside of it? It just returns an empty value.
rextended
Re: Unable to set a local variable  [SOLVED]
Tue Jul 05, 2022 8:01 pm
You test it on terminal?
on terminal
:local x 1
and on the 2nd line, local x do not longer exist.
On terminal you must start everytime with { and end with }
and use correct syntax:
7 code
:local elem         0
:local firstsession "never"
:local usr          "testuser"
:foreach sessid in=[find where user=$usr] do={
    if ($elem = 0) do={
        :set firstsession [get $sessid started]
        :put "First session: $firstsession"
   :set elem ($elem + 1)
:put "User $usr have $elem session(s) and the first is started: $firstsession"
Users browsing this forum: Bing [Bot], techcomtecnico and 51 guests
