Unfilled1865
RB5009 Unable to ping LAN devices, and vice versa  [SOLVED]
Wed Jul 06, 2022 5:40 am
Configuration is a wired router connected to various switches and access points. I updated from RouterOS 7.2 something and now I cannot connect to the RB5009 via IP - only MAC address. Pinging out from the Mikrotik there is no response either. Interestingly all the devices connected to the network can still reach the internet.
I can't seem to figure out the issue here, could someone have a look at my config, and see if anything appears to be wrong? ether8 has the internet instead of ether1, which is the default.
export.txt.rsc
anav
Re: RB5009 Unable to ping LAN devices, and vice versa
Wed Jul 06, 2022 4:21 pm
Rather complex so will just look for obvious stuff.
(1) You have no vlans so I wouldnt set vlan-filtering=yes!
add admin-mac=DC:2C:6E:40:F2:5B auto-mac=no comment=defconf \
ingress-filtering=no name=bridge vlan-filtering=yes
(2) Why is dhcp server disabled?
add address-pool=default-dhcp disabled=yes interface=bridge name=defconf
(3) Seems to be an incomplete entry?
/routing table
add fib name=""
(4) Your attempt to mix ppp and wireguard is very confusing and using similiar names for things
also confusing vpn/VPN.
(5) Why do you have two addresses assigned to the bridge......
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.89.1/24 comment=defconf interface=VPN network=\
192.168.89.0
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
SUMMARY, config is a big jumbled mess that I cannot make heads or tails of. Didnt see anything that would solve your issue.
Unfilled1865
Wed Jul 06, 2022 9:26 pm
Thank you for looking at this. Agreed that this configuration is messy, but this is a hobby for me.
1) Noted, and have disabled it. The problem persists.
2) I have a raspberry pi that handles DNS and DHCP for the network so that is why DHCP is disabled.
3) I haven't made any changes here that I recall. Is possible something got messed up in an update? What should this section typically look like for a home router?
4) I had been using a L2TP/IPSec tunnel, which stopped working a while back because of a windows update. I had disabled the settings related to that and moved to wireguard.
5) That 192.168.88.1 line is disabled. I left most default config items, and just disabled ones I didn't need.
Unfilled1865
Thu Jul 07, 2022 5:20 am
Correction - the pings are being responded to, but the reply from the Mikrotik's address is "Destination host unreachable."
Unfilled1865
Thu Jul 07, 2022 6:58 am
Disabling the last mangle rule appears to fix it. To be honest I don't remember what the purpose of it was.
Users browsing this forum: qatar2022, Tony93 and 118 guests
