Wyz4k
OVPN UDP time-out after 1 hour
Wed Jul 06, 2022 11:23 am
Tested with ROS 7.3.1
I've just recently converted my OVPN TCP tunnels to OVPN UDP and I've noticed that after almost exactly an hour my OpenVPN clients get a hard error that requires the user to click OK and then manually reconnect. Multiple clients are experiencing the same issue.
If the connection timed out and automatically reconnected it would have been better, but because it throws an error it requires user intervention every hour which is really annoying.
Connect time 15:13:38
Sigterm[soft,remove-exit] 16:14:22
Using OpenVPN GUI v11.25.0.0 on the client PC.
2022-07-06 15:13:21 DEPRECATED OPTION: --cipher set to 'AES-256-CBC' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM). Future OpenVPN version will ignore --cipher for cipher negotiations. Add 'AES-256-CBC' to --data-ciphers or change --cipher 'AES-256-CBC' to --data-ciphers-fallback 'AES-256-CBC' to silence this warning.
2022-07-06 15:13:21 OpenVPN 2.5.3 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 17 2021
2022-07-06 15:13:21 Windows version 10.0 (Windows 10 or greater) 64bit
2022-07-06 15:13:21 library versions: OpenSSL 1.1.1k 25 Mar 2021, LZO 2.10
Enter Management Password:
2022-07-06 15:13:21 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
2022-07-06 15:13:22 TCP/UDP: Preserving recently used remote address: [AF_INET]<SERVERIP>:1194
2022-07-06 15:13:22 UDP link local: (not bound)
2022-07-06 15:13:22 UDP link remote: [AF_INET]<SERVERIP>:1194
2022-07-06 15:13:22 [ecoCA2021] Peer Connection Initiated with [AF_INET]<SERVERIP>:1194
2022-07-06 15:13:33 open_tun
2022-07-06 15:13:33 tap-windows6 device [OpenVPN TAP-Windows6] opened
2022-07-06 15:13:33 Set TAP-Windows TUN subnet mode network/local/netmask = 10.0.0.0/10.0.0.4/255.255.255.0 [SUCCEEDED]
2022-07-06 15:13:33 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.0.0.4/255.255.255.0 on interface {4BE91EE1-CDDB-4FC8-BBF0-6AC460A016D0} [DHCP-serv: 10.0.0.254, lease-time: 31536000]
2022-07-06 15:13:33 Successful ARP Flush on interface [11] {4BE91EE1-CDDB-4FC8-BBF0-6AC460A016D0}
2022-07-06 15:13:33 IPv4 MTU set to 1500 on interface 11 using service
2022-07-06 15:13:38 Initialization Sequence Completed
2022-07-06 16:14:22 SIGTERM[soft,remote-exit] received, process exiting
Server settings:
port 1194
mode ip
protocol udp
netmask 24
max MTU 1500
keepalive timeout 60
certificate
require-client-certificate yes
tls version only v1.2 (I tried any before and it made no difference)
Auth sha1
cipher aes256
ppp profile settings:
session timeout - not set
idle timeout - not set
client.ovpn
client
proto udp
remote <SERVERIP> 1194
resolv-retry infinite
dev tun
ca ca.crt
cert client.crt
key client.key
tls-client
nobind
persist-key
persist-tun
cipher AES-256-CBC
auth SHA1
auth-nocache
auth-user-pass auth.txt
route ...
Wyz4k
Re: OVPN UDP time-out after 1 hour
Wed Jul 06, 2022 12:26 pm
Connected at 16:21:29
Disconnected at 17:22:14.
Just over an hour again.
Server logs show:
17:22:13 ovpn,info ovpn-client: terminating... - peer disconnected
17:22:14 ovpn,info,account client logged out, 3663 150404 11810 1270 184 from <CLIENTIP>
17:22:14 ovpn,info ovpn-client: disconnected
basd
Fri Jul 08, 2022 11:05 am
Server logs show:
Same problem here.
After 1 hour i am running 7.3.1 acording to the release notes stability must have been improved but not seeing that
own3r1138
Long time Member
Long time Member
Fri Jul 08, 2022 9:39 pm
Server UDP - 7.3.1 - x86
Client HAP AC3 - 7.3.1
jti
Sat Aug 27, 2022 9:41 pm
Hello, I have the same problem, every hour a disconnect (0-ovpn-CG: terminating... - peer disconnected). Does anyone have an idea what could be the reason? Router OS 7.4.1. Thank you for your answers
Wyz4k
Sun Aug 28, 2022 12:45 pm
MikroTik have confirmed that they can reproduce the problem. So we need to wait for them to fix it.
roe1974
Fri Sep 02, 2022 2:58 pm
Hi ... anyone allready tested with 7.5 ?
br, Richard
own3r1138
Long time Member
Long time Member
Fri Sep 02, 2022 3:02 pm
br, Richard
For me, it's fixed 7.5 x86.
Wyz4k
Sat Sep 03, 2022 4:48 pm
Yep, fixed for me too. For the first time I can stay connected for longer than an hour.
roe1974
Mon Sep 05, 2022 12:30 pm
In the 7.5 thread it says that the connection is no longer closed on the router as soon as the client disconnects it .... could you determine this ?
viewtopic.php?p=955298&hilit=ovpn#p955298
br Richard
spippan
Wed Dec 28, 2022 3:36 pm
has anyone checked on the firewall connection tracking lifetimes?
in addition to that ... is there any sort of keep-alive faciliated?
Users browsing this forum: Demidrol and 188 guests
